is it safe to wash my engine????
Old Oct 4, 2001 | 09:45 AM
87_Camaro's Avatar
when ever i go tot he self car wash i have been wonderign if it's possible to spray my engine with the high pressure hose, would i ruin anything?? thanks
Old Oct 4, 2001 | 10:03 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Just don't blast it up close with full pressure and it'll be fine.Done it many times.Be careful around the distributor or be prepared to pop off the cap and wipe it out.
-Rich-
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Old Oct 4, 2001 | 11:45 AM
Unmarked Vehicle's Avatar
The best advise I can give you is to clean your engine after you are done using it for the day. I do my engine in the evening. Many people have called me saying that their car wont start. After I tell them to leave it alone for a few hours, the car starts right up with no problems. I do not recommend starting it immediately after a wash, especially after using chemicals. A lot of the time, your car's engine will miss and your computer may go out of whack.
Old Oct 4, 2001 | 09:36 PM
LarsZ28's Avatar
I have washed thousands of engine bays, and have only has one car that wouldnt start, due to a coil problem. But about 100 have run rough afterwards, mainly due to moisture (caused by the hot high pressure) on plugs, dizzy caps (front wheel drive cars with over head cams are prone to this, due to the horizontal distributor) I wouldnt wash the engine unless I had access to a air compressor to blow the water out of electrical connections, and around plugs, distributor etc... Water can sit in electrical connections for days, and can rust out and cause all sorts of problems. Also if you get water into your intake, or heads, and then start the car, you risk engine damage (bent conrods.. etc.)
Unmarked Vehicle, if the engine is hot, and you spray it with a cold mist of high pressure water, you run the risk of cracking headers, exhaust, heads.. Maybe not a high risk, but still a possibility.
[This message has been edited by LarsZ28 (edited October 04, 2001).]
Old Oct 4, 2001 | 09:44 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just don't wash it with cold water after the engine has been running and you turn it off, you could crack the block. Or just leave the engine running while you do it.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 4, 2001 | 09:45 PM
Car: 99 Formula
Axle/Gears: 342
Guess I should have finished reading the above post.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Old Oct 4, 2001 | 10:09 PM
<font face="Verdana, Arial" size="2">Originally posted by LarsZ28:
</font>
I absolutely agree. I failed to mention that your car should cool down. Thanks for covering.
Old Oct 5, 2001 | 12:58 PM
colinfinkle's Avatar
I would have a couple plastic bags and some elastics for the distibutor and the air cleanor. There's my 2 cents.
Colin Finkle
87 Sport Coupe Camaro, 5.0 L V8
My Car Craft in/out list:
In: Buying my project Camaro and being the first F-body in High School.
Out: While it is being upgraded 6 V6 F-bodies bodies show up!
Out: Looking like a pazie a** follower.
In: Being the only panzie a** with an 8 under the hood!!!
Grant2k
Jul 10, 2018 04:01 PM
Polo Z03
Sep 10, 2015 06:43 PM
ezobens
Aug 19, 2015 10:29 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
