Can you put hids in the bumper turn signal lights?
Old Dec 31, 2010 | 07:59 AM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
I have a spare hid kit laying around and was thinking of putting hids in the bumper lights if possible thanks.
Old Dec 31, 2010 | 08:05 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Can you put hids in the bumper turn signal lights?
You might be able to. Get under there and try it. Lol.
Old Dec 31, 2010 | 08:13 AM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Thats the plan I just wondered if someone had tried I guess I'll find out and let everyone know.
Old Dec 31, 2010 | 10:58 AM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
well i wouldn't suggest it because of the fact that HIDs have to warm up before they produce the full amount of light they aren't just like light bulbs that turn on and off the gas in the bulb has to heat to produce the power of light that they produce
Old Dec 31, 2010 | 11:30 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Real HID??
IIRC heavier gauge wiring & some type of heavy duty balast // relays are needed for each bulb..??..
Interesting idea!!
Old Dec 31, 2010 | 01:31 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
yeah I have a 35watt kit and have been thinking about it I have 55 watt kit in the lows and bizenon for hi/low so I thought it would look awesome in the front if all the lights were hids
Old Dec 31, 2010 | 02:09 PM
Car: '87 Camaro
Do HID bulbs generate heat?
How would it affect the plastic housings & lenses?
Do they use stock reflectors?
I know nothing about them other than the wires balast & relays need to be up to the task.
If you are able to do it with great results, this may be something for us to try.
The country roads seem to attract deer & other vermin, as well as different degrees of fog!!
Old Dec 31, 2010 | 02:30 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
you'll need to use a retrofit hid bulb that is meant for the socket and bulb type of the original. i dont think the kit you have is going to be correct for the lights you're looking to swap. as for heat, HID's actually burn cooler than standard halogens, so the housing should be ok. HID's are not meant to handle lots of blinking, so I wouldn't use them in any turn signal housings (along with possibly blinding other drivers due to the light pattern).
Old Dec 31, 2010 | 03:00 PM
AmorgetRS's Avatar
Even if you can fit them in there, you shouldn't.
HID are not meant to be turned on and off like a blinker.
You will blind other drivers as the reflector is in no way made for a light that bright in there.
Honestly I can't believe anyone encouraged you to do this...
Old Dec 31, 2010 | 05:58 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
I was just going to modify the back of the housing so the bulb would fit I was going to get different bulbs like the foglights use. The idea was from people having them in their foglights I didnt know if the could take blinking or not, I might try getting some led bulbs or something the kit I have is from vvme they have a one year warranty so if they messed up i could have them replaced as far as blinding people my car is lowered and the 55 watt kits in the headlights are low enough that on coming traffic isnt distracting, so that part would be fine , its just the blinking that concerns me I dont want a fire or anything.
Old Dec 31, 2010 | 11:38 PM
AmorgetRS's Avatar
You are still going to blind people and even if the bulbs don't catch the car on fire everyone coming the other way will want to catch it on fire.
Old Jan 1, 2011 | 02:28 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
I'm planing on using HID's in the turn signal as fog light.
just cut off the back and make two separate areas for the lights, one for turn and one for fog light.
Old Jan 1, 2011 | 05:56 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome idea i want to see the finished product
Old Jan 1, 2011 | 09:03 AM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
I think this would be the best what would be your plan for wiring or are you just throwing ideas, it's definitely a good one.
Old Jan 1, 2011 | 11:22 AM
Axle/Gears: stock
that would be redundant for the fact that if the HIDs are on it would wash out all the light from the blinker bulb
Old Jan 4, 2011 | 12:06 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
I'm considering this for a fog light replacement, so I do not have to have them in the typical location, I was had not considered the turn lights not being seen with the HID's on. but just mostly to pass safety inspection, I a bro has a Buick GN with H4 headlight conversions and they would not pass the car.
Old Jan 4, 2011 | 07:58 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Why not just swap out the factory bulbs for LEDs? Lots of choices and very cheap.
Old Jan 4, 2011 | 09:39 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Sorry if I come off as condescending, but there is a reason why the optics (reflectors or more often projectors) have been specifically designed to handle the type (not just brightness) of light that HID produces. This going for the idea of separating the housing for a fog light/turn signal also.
http://www.danielsternlighting.com/t...nversions.html
Cool alternative...switchback leds. bright white when the parking lights are on...alternate orange/white/orange/white when you hit the turn signals.
http://www.youtube.com/watch?v=YekkmSkc6eI
vleds.com has 2 different types...type 1 which is like those in the video...and type 2....which turns the white bulbs off completely while the orange flashes, and then the white comes back on.
http://www.youtube.com/watch?v=HbNYqw1FCmI
Old Jan 5, 2011 | 01:13 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
I'm just throwing out my crude idea, I enjoy the input of others,
why should I do something and find out it will not work? when some one else has done it that way and had to change it.
everyone has something to bring to the table on our projects.
"Fly Low, Fly Fast DUSTOFF!!"
Not tell I have your wounded!!
Old Jan 6, 2011 | 01:18 AM
riceburner247's Avatar
Car: 1992 Z28
My thoughts exactly.
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
