Sliptone Liquid Metal Polish on TPI Runners!
Old Feb 26, 2011 | 10:26 PM
cferrel4's Avatar
Car: 87 IROC, 2002 Formula, 70 Camaro SS
Engine: 305 tpi, LS1, 383 stroker
Transmission: 5 speed t5, 6 speed & 700r4
So today while I was painting a hood for a neon and bumper for a corolla I decided I would try this new liquid metal polish that autofinishers.inc gave me to try. I tried it on my 87 I-ROC with the original TPI runners I had. I had 3 varying grades, coarse (red), medium (medium) and fine (blue). I was told all I needed was some ultra fine 0000 steel wool and 2 old shirts. So here is everything I needed. I used an old white shirt and an old pillow case. Figured both are cloth... I was supposed to use one to wipe it down between and one to finish.
Here is my 50k Original tpi set up and what it looks like.
I first started with the red coarser polish. Applying a quarter size splash of it to the steel wool. It covered a lot for so little!
Wiped it down with the pillow case, not much progress but still ways to go.
Next I did the green medium grade with a new thing of steel wool for just the green.'
Wiped it down and did the blue grade with another new steel wool. (So I have a separate steel wool for all three grades. I just keep them separately with their respective grades.)
So I wiped it down. Doesn't look like much of any difference at all! Then I took my old white t-shirt(the finishing one) to run that over. And it started shining unlike before!
I tried it on the AC lines and it shines them up very nicely!
I did a spare runner that I had kept from an 89 Iroc that I parted out. Here is the result.
Old Feb 26, 2011 | 11:21 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: Sliptone Liquid Metal Polish on TPI Runners!
nice job
Old Feb 26, 2011 | 11:55 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
looks good. your not planning on taking off the runners and doing that and the plenum and all?
Old Feb 27, 2011 | 10:42 AM
cferrel4's Avatar
I plan on just leaving it like it is for now until something breaks and then when I have to take it all apart I will do the rest of the runners. Car literally only has 50k on it, so I do my best to leave it stock.
It unfortunately doesn't do much for the plenum. I did it several times and scrubbed really hard too. It has to have some sort of different coating or density to it. I ran a spare plenum I had through a wire wheel brush and then did the polish and here is what i got.
Size:  155.4 KBName:  Picture025.jpg
Old Mar 2, 2011 | 03:44 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
I dont know how much of a shine your going to get off of that high spackled surface on the plenum. But the runners look amazing! You have inspired me to do mine as well.
Old Mar 2, 2011 | 03:51 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
sand down the plenum then use that stuff? mirror? lol.
Old Mar 3, 2011 | 01:30 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
for sure the plenum needs to be sanded down smooth for ANY polish to work. Judging by the looks of what it did for the runners though, seems like some pretty good stuff. Sand a small part of that spare runner smooth and try again. It'll shine even more if you start with a smooth level surface. The results of the polish are impressive. Might have to try that stuff myself. Can you buy online?
Old Apr 9, 2011 | 10:29 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
its actually marketed as Gliptone liquid metal polish, even though it looks like an S on the bottle, they have alot of products that you all on here would love
stalkier
Dec 6, 2015 11:25 PM
86IROC112
Sep 29, 2015 04:07 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
