My Camaro Z28 project.
Re: My Camaro Z28 project.
UPDATE !
Spacers installed
Test fit with the spacers :
Annnnnnnnnnd found this :
Where the steering box are bolted. **** my life lol
Bleeded the brakes :
My son helped
Then continu searching for holes :
Started to make plates
Spacers installed
My son helped
Then more plate appears
We made a brace
Moked the plates in place
Installed my other black seat belt
Cut the trip reset button to make the speedo make complete turn, this gonna be fun lol
Messssss
Final product :
Painted my new tranny rad
Painted the 34MM sway bar
Photoshoped the front lip black
We made a brace
Messssss
Final product :
Axle/Gears: 10 Bolt 2.73 Open
Wow, good thing you found that rust before something REALLY bad happened.
Modified gaz pickup for the nitrous fuel system
NOS plate + purge installed.
Still on the block,....
AUX fuel system almost done
W0T switch
Wiring and no more heater core.
WIP block off heater core plate
Possible NOS shoot button placement
NOS bottle almost done
W0T switch
Removed "old ****"
Tested if it fire.
Was not sparking.
You can't put it on switch 8 for 8 cylinders... RTFM! Switch 2, is for 8 cylinders. Switch 6 is for 8 cylinders but with -20 timing below 850RPM. The engine don't like it lol.
So the MSD digital 6 plus is tested working.
Tested if it fire.
Was not sparking.
Modded the steering shaft to **** a bolt on the center
Washed the POS.
Wheeliebar
My car at a local show
Great feedback from ppls. I'm happy.
Interior is complete
Friends
3rd place at limbo 49inchs.
Picked up a dash for 10$, why not.
Wiring the tach adapter wich doesn,t work at all at the moment. Will check this tonight.
Washed the POS.
Wheeliebar
Friends
GVMV
Aug 16, 2015 08:01 PM
