A little autobody detailing help please!
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: Automatic
so how do i get rid of this shiz...? like is there a quick easy fix or no? if so then let me know how i can fix it. Previous owner tore that bumper up
Car: 1991 Camaro RS
Engine: 305 TBI
Re: A little autobody detailing help please!
You may be able to wet sand some of the lighter scratches out. Soak some 800, 1000, 1500, and 2000 grit paper and work your way up to the 2000 then hit it with some rubbing compound and then some polish. For where there paint is gone- well, there is not much you can do except repaint it. Honestly, if you taped it off really well, sanded the daylights out of it primed it, sanded it again, and then painted it with rattle cans and clear coat you could then wet sand it and probably get it to look way better than the gouged mess you currently have. Good luck!
Car: 1992 Camaro RS
Engine: 3.1L V6
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
My front spoiler has a lot of spider cracks throughout the entire thing. Thinking of doing the same...sand...primer and spray on my own with some cans.
Car: 1992 Camaro RS
Engine: 3.1L V6
So what color should i go with since i know itll look like crap if i try to match the color. unless someone has the code for a stock red 1992 camaro rs 25th anniversary edition
Linson
Oct 1, 2015 09:50 PM
