Opinions on Painting Strut Tower Caps
Old Aug 11, 2011 | 10:04 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Not sure if thats what theyre called. But my car is triple black. New motor is Chevy red and black. The strut tower caps look a little Dull so i was thinking about painting the top cap part the same Chevy red as the rest of the motor.
Old Aug 11, 2011 | 10:07 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Opinions on Painting Strut Tower Caps
The red caps would tie in with your red block & wire loom. How about puling the whole strut mount off & repainting it red as well?
Old Aug 11, 2011 | 10:18 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
IMO, they (caps or entire mount) should only be painted if it helps hide them from site. They are not exactly anything appealing to look at or, to have attention drawn to.
Old Aug 11, 2011 | 11:35 PM
AmorgetRS's Avatar
Unless they look like this:
Old Aug 13, 2011 | 09:32 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Old Aug 13, 2011 | 09:38 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
can they be easily removed and replaced...I have wondered about painting them my self
Old Aug 13, 2011 | 10:51 PM
Abubaca's Avatar
Don't paint 'em. They should be black. There are certain parts that regardless of what color your car is, should aways remain black. Small little plastic clips, wire ties, wire looms, hoses (unless braided is necessary), little brackets, etc. etc. I mean ultimately it's your car of course, but.....
Old Aug 14, 2011 | 03:31 PM
Engine: 383 stroker
I wouldnt mind keeping them black but mine are kinda faded and need repainted..so does anybody know about taking them off
Old Aug 17, 2011 | 04:18 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Keep em' black.
Old Aug 17, 2011 | 05:46 PM
Car: GTA
The plastic caps just pop off. The strut mounts are the 3 nuts you see for the alignment & the 1 big nut holding the strut itself.
Old Aug 19, 2011 | 07:30 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
since they're plastic, stick with a plastic dye (like krylon fusion). sticks much better, less chance of runs (from personal experience and mistakes), and much less likely to chip if you have to pull them off for strut replacement
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
