PARADOX!!!
Old Oct 30, 2001 | 10:59 PM
92RSB4C's Avatar
PARADOX!!!
Well, I just got back from driver's ed and done with my homework. Went out to work on my rim that I'm polishing and just got done using 2000 grit paper. I noticed that on one spoke, it is smoother than the rest. I mean it has been sanded down farther with 400 grit and you can't see any machining lines, while on the other spokes you can. After finishing 3 coats of Mothers Aluminum Polish, I noticed the smoother one doesn't have as good as shine as the others. Any help as to why would be appreciated. Oh ya, here's another confusing paradox, I can drive myself to driver's ed now.
Chevy World Home Page Tripod Home Page Speak up for our hot rodding rights!!!
Old Oct 31, 2001 | 09:30 AM
92RSB4C's Avatar
Anyone¿?
Old Oct 31, 2001 | 10:52 AM
prepz28's Avatar
i dont quite understand. However if you sand everything down starting from 220 grit moving up to 2000, it should be all the same. after you sand it with 2000, use some rubbing compound and rub it in for a while. then use mothers or whatever. im kind of confused by your post but i hope that helps. anything else??
Old Oct 31, 2001 | 01:02 PM
ScreaminDeamin85Z's Avatar
try using mothers aluminum polish with some 4 odd steel wool. after that use this stuff you can get from the grocery stroe called "Brasso" and rub that in real good and things should be good.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-305 5spd...Jamex Springs...and thats just about it!Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://ScreaminDeamin.cz28.com
Old Oct 31, 2001 | 02:45 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
You are wetsanding also right?
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: B&B Exhaust, few free mods.
Appearance Mods: SS wheels, 2.5" Cowl Hood... New 100% Black paint job, Clear Side Marker Lights
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Oct 31, 2001 | 06:48 PM
Camarokid01's Avatar
I know exactly what you are talking about 2 of my wheels are very smooth and 2 of them are kind bumpy, it is a factory defect in the wheels I guess. probably would have to do some major sanding to get them smooth.
Old Oct 31, 2001 | 08:35 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
When I did my plenum I used a three part abrasive block. One Red for heavy cutting, green for a nice shine and white to really shine it up. The white buffing compound does better than my mothers aluminum polish. If I hit the plenum with the mothers after the white stuff, it actually dulls it a little.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 31, 2001 | 08:50 PM
Ions91Z28's Avatar
Rob P, the Red ripped the cast off? or did you sand the cast off?
91 Z28
Best Time Slip:
60' - 2.098
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Oct 31, 2001 | 10:47 PM
92RSB4C's Avatar
What I mean is, I didn't spend a lot of time getting the machining lines off. After I sanded the rim with 2000 grit paper and polished, the part of the rim with the machining lines has a better shine than the totally smooth part. The totally smooth part sort of bleeds the shine like unpolished metal. I polished it 3 separate times so I know it's not just a bad polish. My question is why does it do that. Oh ya, I just finished my instruction permit test at the DPS office and I want to ask the question, Why do we need to know the color of the flag that should hang from a tow chain? Is it just another stupid government law or is there logic behind it?
edit: The reason for not totally sanding down the machining lines is 1) I'm lazy and 2) a car that looks really good is more likely to get stolen.
[This message has been edited by 92RSB4C (edited October 31, 2001).]
Old Nov 1, 2001 | 06:40 AM
Ions91Z28's Avatar
Well, I'm far from the smartest person on this... But I'd assume the ones where the machine lines was just sanded better later on with the higher grits. Which is why you can see the machine marks, but still shines. As far as I've known, the smoother the metal, the more shine it can make. Also, if you have a buffer or die grinder, try going to home depot and buying a polishing kit. It'll have four buffing pads and three compounds. Use the white one on the smooth area and see if it doesn't shine alot better.
91 Z28
Best Time Slip:
60' - 2.098
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Nov 1, 2001 | 07:08 PM
Ions91Z28's Avatar
ttt, rob P?
91 Z28
Best Time Slip:
60' - 2.098
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Oddball
May 23, 2013 07:11 PM
CamaroManBlack
Carburetors
Jan 18, 2004 07:39 PM
Eggplant Jeff
Aug 3, 2002 04:50 PM
drive it
Jun 22, 2001 11:45 PM
