How do u make Windshield wiper tanks white again
Old Sep 28, 2011 | 10:13 PM
383RAT's Avatar
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
Does anyone know how to make the windshield wiper tank looking white again from the nasty yellow color it changes to over time?
Old Sep 28, 2011 | 10:53 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: How do u make Windshield wiper tanks white again
get a new one?
Old Sep 28, 2011 | 11:02 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Originally Posted by mjdavis68@yahoo
get a new one?
x2.
or mabe bleach it? I realy have no idea but would like to know though
Old Sep 28, 2011 | 11:46 PM
Stroxell78's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 373
I've bleached them, but it still has a light dingy color to it. But I've also heard of people using drain cleaner, Such as Drano.
Old Sep 29, 2011 | 12:31 AM
mjdavis68's Avatar
Seriously,its a teflon plastic mix and it wont clean up
Old Sep 29, 2011 | 07:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A search is always a good idea on TGO. There's not much that hasn't been asked and answered. Here's a start:
https://www.thirdgen.org/forums/auto...lant-tank.html
JamesC
Old Sep 29, 2011 | 06:04 PM
BobtheGreatII's Avatar
Car: 1982 Pontiac Firebird
Engine: 5.7L Chevy SB 350
Transmission: Turbo 350c
I know it sounds stupid. But I actually just painted mine white. I could have done a better job (got some silly runs) but it looks 100% better. Obvious problem is that you can't see through them, you have to check levels by opening it up. But it was the cheapest/easiest/laziest solution I could find.
Old Sep 29, 2011 | 07:03 PM
K. E. Christy's Avatar
Car: 1991 Z28
Engine: 5.0L TPI
Transmission: 5 Speed
Remove from the car and put it through the dishwasher. Does a great job.....
Old Sep 29, 2011 | 07:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
there is a thread about it on a pontiac website and I cant find it.
some use a multi step process. gas is one of the steps
I have also heard that denture cleaner works but Ive never tried it.
Old Sep 30, 2011 | 07:37 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I tried to get a new one for my 91 no luck
Old Oct 1, 2011 | 01:58 AM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
I used magic erasers and mine look pretty new compared to how yellowed they had become. Try it ...you wont regret it. I was amazed.
Old Oct 1, 2011 | 08:40 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I swapped mine out for a stainless steel one.
Fading problem solved.
Old Oct 4, 2011 | 01:59 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Buy a new one and then never fill it. Mine's been looking great for years!!
Coolant overflow, not so much. I replaced them at the same time, but unlike the washer tank, the coolant tank gets used, so it quickly managed to gain a nice coating of scum on the inside.
Old Oct 4, 2011 | 02:40 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
You can bleach them white with a combination of bleach, Oxyclean and UV light. Unfortunately, that's not the factory fresh appearance of new bottles. I've tried all sorts of things, but if they've yellowed, the easiest fix is get a new one.
Old Oct 4, 2011 | 05:10 PM
one92rs's Avatar
Car: SOLD!!!!!
i need to try to get mine clean so i can sell them. they are sitting on a shelf in my garage and are only a year old. i figure they should clean up pretty easy.
Old Oct 5, 2011 | 08:58 PM
383RAT's Avatar
JamesC
Ok tried drano cleaning that they look much better but not to the point i'm satisfied. The problem is I have the washer tank with the cruise control. I no longer have the cruise control so I can switch to the other washer bottle BUT I got a question. Where does the washer pump go for that bottle. I've already painted my engine bay and pretty much have everything laid out. I'm trying to avoid a large change. The yellowish washer tank issue was purely an oversight by me when working on the car. At the time I started the project the cruise control washer tank was still available. Unfortunately I simply forgot to buy it and now I can't find new one.
Old Oct 10, 2011 | 11:24 PM
383RAT's Avatar
Ok never mind I went to the junk yard today and saw the other style windshield wiper tank and how the remote pump is mounted. I think i'll live with a slightly yellow windshield washer tank. Unless someone knows a place I can buy a new windshield washer tank with the integral mounted pump.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
eddie jr
Aug 25, 2015 06:52 PM
