Ebay housings fogging up? Help?
Subscribe
Jan 6, 2012 | 06:07 PM
I bought the fake projector housings (black) and i just got done installin them and they immediately started fogging up.
The housing itself also got very hot.
Im running the bulbs they provided (h4s)
Is there any solution to this or did i just blow 50$?
Reply 0
Jan 6, 2012 | 06:20 PM
Re: Ebay housings fogging up? Help?
John, did you and santiaga get the front struts on?
The reason their fogging up is because its humid where we live. The heat from the bulbs are gonna cause the moisture in the air to condensate to the glass lense.
Like a can of beer you drink on a hot summer day
I say you blow the $50 to get my poly mounts put on.
Reply 0
Jan 6, 2012 | 06:23 PM
So youre saying these housings wont work for anyone who lives in humid places?
Reply 0
Jan 6, 2012 | 06:50 PM
if they are fogging there is either excessive moisture in the housing (assuming its sealed) or the housing isn't sealed and humid air is getting in through the leak. take the bulb out, dry the housing (blow dryer or similar), and replace the bulb insuring a good seal. if that doesn't work there is probably a leak somewhere you'll have to find. for $50, I'm betting they are not sealed well
Reply 0
Jan 6, 2012 | 06:54 PM
Quote: if they are fogging there is either excessive moisture in the housing (assuming its sealed) or the housing isn't sealed and humid air is getting in through the leak. take the bulb out, dry the housing (blow dryer or similar), and replace the bulb insuring a good seal. if that doesn't work there is probably a leak somewhere you'll have to find. for $50, I'm betting they are not sealed well
Hey sail thanks for the reply
So youre saying i should seal up the edges of where the glass meets the
housing with silicone maybe? And the bulb area?
I was thinkin about drilling a hole somewhere instead would that just make it worse?
Reply 0
Jan 6, 2012 | 07:17 PM
what is it with you wanting to use silicone o everything, John? haha
yeah use CLEAR or BALCk, not the red copper based kind you use. Also, where the socket where th bulb goes into. make sure thats sealed too.
and no drilling holes. the moisture will blow up the bulb if it hasnt happened yet.
Reply 0
Jan 6, 2012 | 07:42 PM
I have the same fakes, mine don't fog up but they are entirely useless as far as focusing light.
If your interested in something with a little more quality, I've done my research on these and they are supposed to seal and focus very well- http://www.ebay.com/itm/165mm-H4656-...sories&vxp=mtr
Reply 0
Jan 6, 2012 | 07:52 PM
Quote: I have the same fakes, mine don't fog up but they are entirely useless as far as focusing light.
Thanks for the suggestion
Do u run the bulbs that came with the housings?
Heres what i have, they have an extra "city light" in the back im sure that didnt help seal any better...
Reply 0
Jan 6, 2012 | 09:09 PM
how ever you want to do it really, as long as its a airtight seal in the end. I'm not sure of how they are constructed exactly so it's hard to say what the best method is. I would use black and clear (as said) silicone, or if you have some fab skill take them apart and use a permanent epoxy of some kind and essentially remake the housings making them nicer and air tight
A hole would kinda fix the problem if its big enough and allows enough air flow/exchange with external air, but in certain situations I imagine you would still have issues, along with what faster said about bulb damage, plus your lenses would get dirty from road grime.
EDIT - I bet that rivet leaks big time
Reply 0
Jan 6, 2012 | 11:18 PM
i had the same problem on another car i had, aftermarket lenses. siliconed the edge where the "glass" meets the housing. no more foggies.
Reply 0
Jan 7, 2012 | 03:04 AM
did u buy this? and do you have pics of them installed?...
Reply 0
Jan 13, 2012 | 07:54 PM
Quote: did u buy this? and do you have pics of them installed?...
No, I have it on my "To order" list. Currently have a 350 build in progress that's taking up most of my funds haha.
John, I am running a set of 8000K HID's in the housings. The ones that I have are slightly different from yours, maybe an older/newer version but it still has the "city" lights.
The HID setup works awesome, but its like trying to use a flashlight without the reflector. It just kind of glows, no light focusing at all. Right now they're aimed very low too, so it doesn't blind anybody.
Reply 0
Jan 13, 2012 | 08:12 PM
Quote: No, I have it on my "To order" list. Currently have a 350 build in progress that's taking up most of my funds haha.
Hey man, i ordered the housings that u suggested they should get here tuesday. I contacted the seller he said he had no fogging issues so hopefully they work out.
Last wednesday i installed 6k HIDS into the ebay housings i have just to see what would happen and i have to say wow.
With 6k HIDs it was as if i had no light on, and on top of that they still fogged up lol.
Hopefully the euro housings do better i will definetly post an update so people dont make the same mistake i did.
Thanks 885speed
Reply 0
Jan 13, 2012 | 08:38 PM
Quote: Hey man, i ordered the housings that u suggested they should get here tuesday. I contacted the seller he said he had no fogging issues so hopefully they work out.
Thanks 885speed
Did you get a Hi/Low beam kit?
If you did, and you have any trouble with the ballasts igniting both bulbs or whatever let me know, because I had to dig up some info and wound up swapping some pins in the socket to make it work properly.
I'm always glad to help others bud, no prob. Post up some info on the new ones when you get em' and we'll call it even haha
Reply 0
Jan 14, 2012 | 12:23 AM
Thanks 885speed
yes can you plz post of sum pics...
Reply 0
Jan 14, 2012 | 12:09 PM
Hey guys to my surprise the euro housings arrived today, shipping was very fast.
Right off the bat i can say that these housings are far superior to the other fake projector housings. Tried them out and no fogging at all.
They feel very solid and well made heres a few pics.
Reply 0
Jan 14, 2012 | 12:27 PM
Quote: Hey guys to my surprise the euro housings arrived today, shipping was very fast.
thats looks good. how much brighter are they to the fake projectors and to stock?..
Reply 0
Jan 14, 2012 | 04:55 PM
Looks great so far!
Reply 0
Jan 14, 2012 | 08:49 PM
Tried the hids in them they were too bright so i aimed them down, they put out a lot of light.
Hope this helps u guys.
Reply 0
Jan 14, 2012 | 11:19 PM
That looks great! I think im gona order some of this also.
Reply 0
Jan 15, 2012 | 12:50 AM
Looks awesome, thanks for the update!
Reply 0
Jan 15, 2012 | 01:04 AM
they look stock untill night ...... thats cool
Reply 0
Jan 19, 2012 | 04:06 PM
What you want to do is install a set of these adapters into your euro housings. These "help" reduce the amount of light that is cast onto the bottom of the housing. You will never get a clean cut line unless you use true HID projector housings. I am running these adapters on my euro glass housings and they put out a ton of light, but do not blind oncoming traffic. Once the 4300K bulbs warm up, it looks only mildly whiter than halogen so as not to attract attention.
http://www.hidexpert.com/producthtml/h4_adapters.html
These can also be found on ebay.
I have a youtube video of my headlights on my site, follow the link below.
Will
Reply 0
Jan 19, 2012 | 04:37 PM
Are you kidding me? That is awesome!
This whole time I've been feeling guilty about my lights being too bright so I've been having them face down. This is great, I will def get these something is better than nothing!
Thanks for info!
Reply 0
Jan 19, 2012 | 04:46 PM
I have the same autopal housings in my blazer with 6k hid's. My Hi/low bixenon hid's came with a cover like the one posted above already on the bulbs, they are deffinatly needed! I tried running them without the cover, and they where all over the place.
Im also going to get a set for my third gen soon.
Reply 0
Jan 19, 2012 | 04:53 PM
Unfortunately mine didn't come with anything like that. So at night I can see a big glare circle on the road which is annoying.
I went with 6k hids thinking they wer pure white but it has some blue in there that I don't like so I'm gonna try a lower k.
Reply 0
Jan 19, 2012 | 11:04 PM
Quote: Unfortunately mine didn't come with anything like that. So at night I can see a big glare circle on the road which is annoying.
My 6k are Pure white. I almost want a little blue hue.
Reply 0
Jan 20, 2012 | 01:19 AM
Quote: My 6k are Pure white. I almost want a little blue hue.
Must be a brand thing? I'm considering 5k.
Reply 0
Jan 20, 2012 | 05:56 PM
Quote:
This is with the HID bulbs?
That has got to be the worst HID pattern I have ever seen. I guess that is what happens when you put HIDs in non-projector housings.
HIDs should have a very even output with distinct cutoffs. Should look like this.
Reply 0
Jan 20, 2012 | 06:33 PM
Delete
Reply 0
Feb 1, 2012 | 10:12 PM
wanted to do an update, i got the h4 shields suggested above and the lighting is 100% better and its no longer too bright for traffic. Highly recommend u guys getting the shields heres the new output
Reply 0
Feb 2, 2012 | 06:01 PM
Thanks for info!
Thank you for being so conscientious, I dont know how many times I've cursed someone putting HID's into non-originally equipped cars and then not adjust their aim. I once pulled over to let someone pass then drove a shortt while behind them with my high beams on to make a point. Was an older civic.
Yeah, I'm a grumpy old man hehe! If it didn't happen so often I'd never have done that though. Seems to happen a lot in the 'Brampton' zone for those in the GTA area.
Reply 0
Subscribe
