high heat rated paint
Old Feb 23, 2012 | 09:58 PM
ChevyRS-305's Avatar
Well i have asked my paint rep this same question and he didnt give me the answer i was looking for. First thing first my car is mostly show but i go for an ocassional drive... i wanted to ask if any of you have an idea that would allow me to paint my engine block in order to match body color. Right now i am using that dulicolor engine enamel but doesnt match my color well enough. My paint rep said i could use our regular ppg base and clear but doesnt know how well it will hold up to the heat. Please help.
Old Feb 23, 2012 | 10:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: high heat rated paint
Regular paint is fine. How hot do you think black paint gets in Arizona in summer ?
How hot does your engine get ? If it's past the above, you'd probably be posting in the cooling forum.
I'd probably skip the bc/cc and just use single stage, it's an engine... how glossy does it need to be ?
Around the exhaust ports would 'probably' be the only concern area. But, I've yet to see a problem with regular duplicolor. Powdercoat didn't discolor or bubble around the ports on Pillsbry10s ports on his turbo v6 so...
Old Feb 23, 2012 | 10:47 PM
Yea my paint rep said the same thing about black paint... dont hold me to ot but i think he said xots rates to 300°
I never actualy measured the external block temp at max temp before...im guessing 4- 500°??
And i have aluminum heads so they wont be painted just the block itself
Also i would go single stage but we cant mix single stage metallic colors. My stripes are 815k which is chevy arrival blue( used on the ss cobalt and silverado) i mean duplicolor looks fine but i like to go with that extra detail ya know. I know kandied91z painted his ls engine candy red but he is never on anymore to ask about it.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
zayne0
Aug 24, 2015 07:22 PM
tmellott89
Aug 16, 2015 02:58 PM
