harness routing
Old Mar 11, 2012 | 02:10 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
harness routing
what tricks have you done to clean up the harenesses in your eng bay weather it be modded or stock? im looking for ideas i can build upon when i pull my motor. im running the FAST ez system so most of my orig harness isnt used anymore and the FAST harness will allow me to to do do things my stock harness wouldnt.
Old Mar 11, 2012 | 05:44 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
Re: harness routing
I took mine through the firewall instead of the kick panel. looks a lot better
Old Mar 15, 2012 | 12:02 PM
Firebat's Avatar
Re: harness routing
My LT1 engine harness wires and power wire(s) from the battery go through the A/C wire hole. It's a the factory hole in the firewall where the HVAC or A/C wires go through.
Bulkhead removed and hole welded up. Those former bulkhead and other wires go through a drilled 3/4"? hole (with a grommet) behind the drivers side fender and those wires come out where the horn is. The hole on the interior side that I drilled out is located up high behind the driver's side kick panel or maybe even above the drivers kick panel.
In the future, I think I'm going to move all wires through the HVAC wiring hole. Right now I have a rear mounted battery but plan on going back to a battery in the engine bay because don't really need the battery back there. So, not having a zero gauge wire there should clear up some room. I also want to take a engine bay relay/fuse box from a newer vehicle so all my relays in the engine bay look nicer and are all in one location.
Old Mar 17, 2012 | 04:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: harness routing
Originally Posted by Firebat
a engine bay relay/fuse box ...so all my relays in the engine bay look nicer and are all in one location.
Old Mar 18, 2012 | 06:08 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: harness routing
Deadbird, is that under the battery tray area? That's where I mounted my ecm. Bolted the fuseblock vertically above it.
Old Mar 18, 2012 | 09:26 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: harness routing
Is indeed, it's on the passenger side.
Old Mar 18, 2012 | 10:01 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: harness routing
Did you put in an access/beauty cover or is it open to the enginebay? Looks like my kind of wiring.
Old Mar 18, 2012 | 10:18 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: harness routing
It's a tight fit to get all the wiring in there. I haven't gotten around to the cover for it yet. Air filter box then hides the cover. So, really, going through all the effort to neatly run the wires was... kind of pointless, lol.
Old Mar 20, 2012 | 09:57 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: harness routing
firebat, is it possible to shoot a pic of your setup?
gixxer92
Apr 12, 2022 12:09 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
crystal383
Interior Parts Wanted
Sep 22, 2015 01:20 PM
Camaroguy2
Sep 22, 2015 08:22 AM
gta892000
Sep 16, 2015 12:37 AM
