Another caliper painting post. Please, advice!
Old Nov 12, 2001 | 06:46 PM
Monkie's Avatar
I plan on painting my calipers but I dont know about how to go about doing it. I plan on getting steel brake lines, should I wait to paint the calipers when I do the brake lines? And should I take the calipers all the way off the car and take the pads off too? Oh and also, would red look ok on a blue car??? Thanks
Old Nov 12, 2001 | 09:56 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
I would take them completely off and do them at the same time you replace the lines. When you do this, of course inspect the pads for wear and replace them if necessary. You may want to look into getting them powdercoated as well. As far as the color, I dunno how it would look on your car, but blue Z06s come from the factory with red calipers...
[This message has been edited by Fbird88 (edited November 12, 2001).]
Old Nov 13, 2001 | 01:40 AM
Jza's Avatar
Jza
I just got remans and painted those and put them on. It'd be better to do it all at once, then you only have to bleed the brakes once. Also, before you commit to a paint, test it somewhere else by spraying it on something metal, letting it dry, then seeing if brake fluid takes it off. Learned that one the hard way.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
