Is there a way to paint the engine bay without removing the engine?
Old May 22, 2012 | 10:11 AM
locke577's Avatar
Car: 1984 Berlinetta Camaro
Engine: '97 LT1
I'd like to have my engine bay cleaned and repainted. Is there any way I can have this done without removing the engine?
Old May 23, 2012 | 12:37 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Is there a way to paint the engine bay without removing the engine?
Since I've spent a dozen hours the past two days working on my wiring, I've thought about the same thing!
There really isn't a real big portion of visible color with everything in place. I'm thinking it could be done once the coolant and washer bottles as well as the battery were removed. Cover all looms and a/c lines with wrapped aluminum foil and then an old heavy blanket could be draped over the engine. Tape and mask off the plastic cowl upwards as well as the front quarters and radiator area and a spray job should seem do-able. Anyone tried this idea?
Old May 23, 2012 | 12:53 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
dont see why it wouldnt work..id just be worried about overspray so mask it like mad
Old May 23, 2012 | 01:04 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Ive done it before. it doesnt turn out perfect but it turns out pretty well. I am actually going to redo it within the next few weeks.
Old May 25, 2012 | 06:02 PM
majobis's Avatar
Axle/Gears: G92
What did you use for paint and what type of finish did you use (semi-gloss, flat etc)? My car is white and I'm looking for the best, closer to stock look until I get the whole car repainted next year.
Old May 26, 2012 | 12:01 AM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
i would also like to know about this. im paying attention!!!
Old May 26, 2012 | 02:47 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Heres a link to a thread in which the individual did the work theirself. Looks quite nice.
https://www.thirdgen.org/forums/auto...bay-cheap.html
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
