WRAPPING the 84 Z28
WRAPPING the 84 Z28
Since im poor and always willing to try something out, i decided to wrap my own car.
I took the Gunmetal metallic vinyl (150 micron thickness)
I did it outside and all by myself (
Better to do it inside and at least 2 persons.
it costed me about 400 euro's and a lot! of patience.
)Better to do it inside and at least 2 persons.
Re: WRAPPING the 84 Z28
Not very clear but here i just did the hood.
I applied them wet, so after sticking it on the car i had to wait till it was dry, then i took care of bubbles and wrinkles.
Im also putting on Heritage Stripes (white).
I had them custom made with 5.7 LTR on it.
The car is almost finished, ill put pictures online later!
windows will be 35% tinted also.
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Very interesting! I have always wanted to find out about car wraps!
Car: 1984 Camaro Sport Coupe
Engine: 2.8l v6 soon to be 350
Transmission: auto
I see you had what looked like decent paint there to begin with. Always wondered if this would work over a proper primer job...
Can't wait to see the finished car. Looks great so far!
COTM Editor
Looks pretty cool so far! What color are the stripes?
the stripes are white.
The car's paint looked okay, but it wasnt, the hood was darker blue, and it had many chips, scratches and some rust spots.
i took care of it all.
You should think the vinyl would cover up some minor imperfections, but it doesnt.
A small scratch from rough sanding will show in the vinyl!
So it wont be a quick easy fix for that.
But it is fun to do, you have to clean the doors from its handle, lock, weather strips, etc.
I also took my windshield out for easier working, but it also was falling apart because of moisture, it has a new window now.
I even had repaired a big chip with bondo, the vinyl ripped it right off.
So beware of that.
Car: 83Z28 HO
Transmission: G Force 5 speed
Wow!! That looks pretty awesome!! I honestly didn't think wrap could look that good.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
im wondering that too, to be honest.
I do have 2 electric fans and ill keep an eye on it.
If it affect cooling too much in a bad way, ill cut it open again.
On the other hand, later model camaro's don't have those holes either...
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
very neat..starting to give me ideas since im no painter. and i always wondered how the 82-84 front chin holes would look filled in and i kinda like it. i was looking at the front view pics wondering (what the heck looks differant
). then i read on and agree
). then i read on and agree Last edited by cIaRmOaCrZo; Jun 11, 2012 at 03:49 PM.
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
ive been debating on wrappin my car either matte red or matte white. how hard was it to do and was it your first time wrapping?
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Looks great but im wonering how well it will hold up to rocks and door dings? Great job and color choice
Just do 1 section at a time and i used some soapy water to make the job somewhat easier.
The vinyl is user friendly, you can shrink it, stretch it and do it over again.
on the front you have to cheat a little, because the deep pockets are too deep to stretch it that much.
I used a plastic scraper with a sock around it and a hairdryer and a heatgun.
it is fragile i must say, you can wash it like normally, but if i put my nail in it hard, it will show.
I didnt had much choice for colors at the time, only brown, blue, dark grey, gunmetal, black and white (metallic colors that is)
They have other colors but those are much thinner, and not for full car wrap.
Make sure you get the EXTREME wrap and not the EASY wrap
I tried doing the headlight buckets in 1 piece, but it was too much stretch for the vinyl.
So i used a separate piece, the edges are at the same place as where my headlight clearcovers are going to be, so it wont show.
The whole front is the hardest to do, deep holes and sharp edges, you have to cheat a little.
one tip: i used a thin line of superglue on the edges where the vinyl ends, it wont show and it will keep the vinyl on its place, otherwise there is a good chance the vinyl will crawl back.
Second tip: don't try to stretch the vinyl cold, it will tear. always heat it up.
If someone will try this also, feel free to ask me anything!
Car: 1987 IROC
like where the quarter panel and roof meet by the rear hatch glass. is there a line from the 2 layers of vinyl overlapping?
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Talk about being different. I like what you did with the wrap. Definitely a new look for the thirdgen. You did a good job. You have mad skills.
That's the only problem with these cars, you cant do the roof and quarter panels with 1 layer.
If you have t-tops you dont have that problem, then you can take 1 long piece and do both rear quarters together.
the roof and a-pillars are done in 1 layer.
COTM Editor
quality is okay, i still have to do the hood stickers.
I do have a hard time getting the airbubbles out, i must say.
Don't know if it has to do with the quality or my lack of experience.
COTM Editor
Same guy I talked to. I'm having him send me samples of his material for the Z03 haha. I have never done a vinyl anything so might be a lot of learning for both of us.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
no overlapping, the 2 layers are cut at 1 line, so to speak.
I understand layers to be something like one sheet on top of each other. Similar to an onion.
I'm assuming that you would only have one layer over the entire car, but would use multiple sheets of the wrap next to each other. I hope that is clear.
If I have that correct, then what you're saying is that the edges are cut at 1 line to make an nearly invisible seam?
Please don't take offense, I'm a little confused. By layer do you mean sheets?
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I have to say it looks really good, you did a great job and it proves its all in the prep, nice job Brother
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
That turned out very nice! ESPECIALLY for doing it by yourself!!!! I had a hell of a time doing my interior pieces by myself let alone a whole car. Cuddos to you for taking on the challenge
that looks really good
