My 89 RS V8 TPI Swap..with GTA digital dash
Old Jun 26, 2012 | 09:49 PM
JeremyE's Avatar
Car: 89 RS tpi swapped
Engine: LB9 5.0 TPI
Axle/Gears: 3.42 open
HelloThis is my first post on TGO about my second ever fbody and so far my favorite after about 10 days of her driving Me and my Dad put alot of work into her but it was worth it.
This is my 89 RS that was originally a 2.8L. I bought it after an unfortunate title issue with my 87 GTA, for $500 with plans to swap the engine and trans over and keep the original dash. But it turned into swapping all but the headlight harness from the GTA wiring wise mainly due to the original wiring being set up for a 2 wire alternator and the GTAs being a 3. We couldn't find any real info to get it charging so we just swapped all the wiring(including tailights!)over in the interest of saving time(my DD so it needed to be on the road asap)and headache from repining and whatnot. and now I have the only Camaro with a GTA digi dash I can find on TGO. I plan on swapping the GTA door panels over soon too and putting a 91-92 z28 wing on that came with the Camaro. So far her only mods are hedman shorties w/y-pipe. And I've still got some buttoning up to do on the dash(underdash panels)and motor(heater hoses/wire routing) but for now she drives beautifully
The GTA
Before the swap
The swap(changed rear main, oil pressure sender since it spewed about a quartiish a week, k member swapped and painted aswell)
(pic limit more coming..)
JeremyE's Avatar
Engine: LB9 5.0 TPI
Re: My 89 RS V8 TPI Swap..with GTA digital dash
(these are just for show lol, we couldn't get a steep enough angle to put both in together)
Old Jun 26, 2012 | 09:58 PM
JeremyE's Avatar
Engine: LB9 5.0 TPI
(in the pics above you can see what the previous owner did to the GTAs carpet..spray painted, like the rest of the interior)
Drove around like this a few days to show off lol
Had to put that heavy SOB on by myself before work since it was going to rain..what a blast that was
Old Jun 26, 2012 | 10:01 PM
JeremyE's Avatar
Engine: LB9 5.0 TPI
Here she is atm. Painted the wheel, got rid of the aftermarket temp gauge(the ta had a pillar pod with it)and put the sender in its place so the temp is on the dash now. And got 14 gauge speaker wiring ran and radio installed
Old Jun 27, 2012 | 11:07 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Looks like a cool project you got there. Once painted and wheels cleaned up more she will look great.
Old Jul 4, 2012 | 05:29 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Might you have any in-progress pics of the dash swap? I might end up putting my Bird dash in the IROC unless I can get my hands on a 4th gen dash soon (don't have a dash for the 88 ), and I was wondering how much of the side brackets you cut off?
Old Jul 4, 2012 | 08:33 AM
Blue1990camaro's Avatar
thats badASS! looking good bro
Old Jul 4, 2012 | 12:05 PM
JeremyE's Avatar
Engine: LB9 5.0 TPI
No I didn't think to get any On the bird the side brackets are just spot welded on and if you start wiggling them back and forth you'll eventually just break the spot welds after a minute or 2 and take the entire bracket. On the Camaro we just cut as much off to get as close to the body as we could with a sawzall.
Old Jul 4, 2012 | 12:09 PM
JeremyE's Avatar
Engine: LB9 5.0 TPI
Thanks Paint is coming in the next month or 2, wheels I'm prob gonna get some 5th gen Camaro wheels or some Vette wheels. Those came on the GTA and I've never cared much for them.
Old Jul 4, 2012 | 12:14 PM
JeremyE's Avatar
Engine: LB9 5.0 TPI
Thank you
Here she is atm. Took the decklid off the GTA and welded the holes up and bondo'd it up and got the 91 z28 spoiler on And I got tired of the yellow spots on the bumper so I just ran some mineral spirits on it and threw a quick coat of black and clear just to make it better for now
Old Nov 24, 2012 | 10:17 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
so was the digi dash swap as hard as i imagine or was it (ik its not simple but) as simple as taking the dash/harness/ecm form the bird, and installing it all in the camaro? like basically swapping it into another gta? or was there some custom work to be done, ik the brackets were probably tough as mentioned but anything else? hows it line up? vents work good?
Old Nov 26, 2012 | 11:54 PM
JeremyE's Avatar
Engine: LB9 5.0 TPI
It was as simple as that. We just took EVERY harness from the GTA to the Camaro. Engine/dash/console all the way to the tail lights were from the GTA(we did it in the interest of time/not wanting to do any splicing/tracing). Just took a few hours is all. And the brackets were super easy. You just need the little bottom piece from the GTA(don't even gotta cut it, just start pulling on it back and forth until the spot welds break). Where the Camaro dash attaches top and bottom on each side mount(you gotta cut it out). And aligning it we simply eyed the mount by referencing the same points on each car and we tacked em in place. You could measure it I guess but that seriously worked perfect. Fitment was great, didn't rattle or anything. All vents worked as they should(get the console vent thing from a TA the Camaro one is a bit too long for the TA's radio thing to go on). I loved that dash in that car so much better than the GTA. If I still had it I'd go take some pics but she's long gone
Old Nov 27, 2012 | 02:15 AM
kmcn47's Avatar
Transmission: 5spd
awe damn, sold it? crashed? you cant start a good looking camaro build then drop that bomb
Old Dec 3, 2012 | 06:51 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Looks great! how long did it take you to do the dash swap? and did you have any wiring diagrams to help you?
The_Phoenix
Feb 4, 2016 07:10 AM
IBrockZ
Aug 20, 2015 12:20 PM
Street Lethal
Aug 14, 2015 08:25 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
