lighting help
Old Nov 19, 2001 | 10:25 PM
harvtherabbit's Avatar
lighting help
i just replaced the bulbs in my dash with blue ones witch look really great but the orange neadles look **** colored is there any way to change it my gauges look so cool besides that any help would be apreciated
Old Nov 20, 2001 | 09:24 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
What car? Camaro? Firebird? Year?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Nov 20, 2001 | 05:20 PM
it an 86 TA with the 140 mph spedo everything was amber and now that i changed the ligh color the neadels are drownish looking
Old Nov 20, 2001 | 07:31 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I'd go with red or blue needles. You can paint them with anything even markers. I used model paint and a brush.
-Matt
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, 8mm AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
- Profesionally Built Turbo-350 with 2500 RPM Stall converter, Hurst shifter, & one wicked shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat., B&M Megashifter, & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
Old Nov 21, 2001 | 09:56 PM
but changing the color of the neadles will only make them darker browenish color no?????
Old Nov 22, 2001 | 12:19 AM
BAK12484's Avatar
most needles are only painted on the back...so if you take some fine grit sand paper and sand off the orange/amber you should be able to repaint them then. Either use a sharpie permanent marker or any kind of paint you want. Or...if you want something bada$$ check these out...
Importintelligence.com They are a bit pricey but would be something different
Old Nov 23, 2001 | 05:49 PM
did anyone ever use those lighted nedadles there hott looking i wonder if they will work in our cars???
Old Nov 23, 2001 | 07:45 PM
crucial's Avatar
No they wont work in our cars because our needles arent transparent. It will probably work in 90-92 cars because they have the backlite guages with backlit needles. I think I'm gonna try that. I remember the needle have a channel inside it for the light to travel trough from under the gauge face.
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
Old Nov 23, 2001 | 08:57 PM
yeah but they say on the website that it uses a light that is added to the neadle to light it?so it should still work???no"?
Old Nov 23, 2001 | 10:56 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
If anyone comes up with ideas for the lighted needle, i would be glad to test it out for them.
Old Nov 25, 2001 | 07:09 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Man those blue ones look errie.
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400small block
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
