Help-Polished Rhims
Old Nov 24, 2001 | 12:49 PM
DansZ87's Avatar
Car: 91 Z28
Transmission: 700 R4
Help-Polished Rhims
HI, i have an 87 iroc and i want to get the rhims polished. I would like to do it myself. does anybody have directions on how to do it. thanks dan
Old Nov 24, 2001 | 03:13 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Gets some polishing or rubbing compound from you local auto parts store, rub on , let dry , rub off. I got some for 2 bucks at pep boys and it worked great on the parts of my rim that are not damaged for good.
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400small block
Old Nov 24, 2001 | 07:05 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Lots of sanding, lots of sanding...btw, lots of sanding.
Start with 120 (i used 80 to speed it up) and sand until all lines/cast is off. Once it's smooth and scratched all up, move to 180, do that until all the 80/120 scratches turn into 180 scratches. Do the same with 240 over 180. Then 320 of 240, followed by 400, 600 dry and wet sand it, hit with 800 (wet only from now on), 1000, 1500, 2000. Use mothers or other polish.
This is a little overboard, but you can't go wrong with it. Just very time consuming. This will not turn out as good as shine as having them professionally polished, with the use of wheels and such. But they'll turn out pretty good. Check out TPI383 I believe thats who it is.
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: SLP Catback
Appearance Mods: SS wheels, 2.5" Cowl Hood, Clear Side Marker Lights
ICQ: 1437212
AOL: normalmatt9
More Pictures are Here
Old Nov 25, 2001 | 01:11 PM
DansZ87's Avatar
Car: 91 Z28
Thanks man i will go ahead and try it. do u got any pics or anything???
Old Nov 25, 2001 | 10:38 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Ions, do you think it would turn out alright if I went 120>240>400>600>1500 and then buffed and polished them? I have done body work before, and normally that combination would make lacquer shine like glass...
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Nov 25, 2001 | 10:45 PM
Ions91Z28's Avatar
Not sure. I've heard the 120 - 180 -240 -320 are the most important stages in metal polish. I think you could skip the 180 and 320 just make sure you do good with the 240 and 400. Anything above that is just looking for that mirror look... which is hard to do with sand paper. You can get a good shine, but it'll never compare to a buffing wheel and white rogue compound.
Oh, and nope don't have any pictures. I just bought my SS wheels not long ago, and started polishing my 91. TPI383 has done his/hers. So far, I've just been working to get the cast off. It's not a very quick process, just a warning. Removing the cast takes along time... atleast by hand. I broke out the dremel a few times, and made me a few trenches and realized I should just take the time to do it by hand.
91 Z28
Best Time Slip:
60' - 2.098
ICQ: 1437212
AOL: normalmatt9
[This message has been edited by Ions91Z28 (edited November 25, 2001).]
