Polishing the 'ol tpi stuff, check it out and let me know what you think
Old Nov 15, 2001 | 12:31 PM
leirch's Avatar
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Nov 15, 2001 | 12:57 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Lookin good. Now the hard part, getting all the waves out. I know your pain I started the same thing, then decided against it and powdercoated everything
Chris
1986 Iroc 355 TPI coming soon
1985 Z28/5-speed Daily Driver
Old Nov 15, 2001 | 01:40 PM
leirch's Avatar
Thanks, Oh I WILL get the waves out and it will be a mirror before I'm done
Old Nov 15, 2001 | 11:28 PM
Kandied91z's Avatar
get the grain out and it'll look sweet; you might want to clear coat it as an added protectant.
Old Nov 16, 2001 | 11:10 PM
Mo's Avatar
Mo
Nuff,
What color did you powder coat it? have any pics?
Old Nov 29, 2001 | 12:10 PM
leirch's Avatar
Here is an updated picture, I don't have a whole lot of time to work on the sanding so its going a little slow.
1987 IROC-Z, engine, tranny, and other "stuff"
Old Nov 29, 2001 | 12:16 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Looking good man. I want me a super ram!
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: SLP Catback
Appearance Mods: SS wheels, 2.5" Cowl Hood, Clear Side Marker Lights
ICQ: 1437212
AOL: normalmatt9
More Pictures are Here
Old Nov 29, 2001 | 12:23 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
How'd you shine it up like that?
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC In Readers Rides
My IROC
Listen To The Exhaust!
Old Nov 29, 2001 | 12:52 PM
Ions91Z28's Avatar
I'd guess sand paper very high grits followed by some white rogue, possible used tripoli before it as well.
91 Z28
Best Time Slip:
60' - 2.098
ICQ: 1437212
AOL: normalmatt9
Old Nov 29, 2001 | 01:45 PM
leirch's Avatar
From far away its looks great, not mirror quality but looks damm good for what it is. If you get close to it you can still see some fine scratches but I'm just after an overall 5 foot away appearance enhancement.
The plenum has been sanded with the drill with a 36grit wheels, then handsanded with 180/280/400 grit paper, then polished with that "polish bar" that you see in the picture, if you look at the lid and notice the one area that shinier than the rest is where I polished so far. So most of the shine is from the polish.
Brendan
Old Nov 29, 2001 | 02:26 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
that 36 grit wheel was a pretty harsh starting point. If you want to get all those lines out, focus on 100, then 180 again, and get it really flat and get all the big scratches out. then wetsand with 400, 600, 1500. If you put enough work into it, it will be as smooth as glass, with virtually no scratches. Then some compounds to finish, and it'll be as reflective as glass.
Old Nov 29, 2001 | 03:34 PM
mcconahay37's Avatar
Does anyone else have pics of their polished TPI setups?
Feel free to donate to the Matt Needs An Engine That Runs fund
82 Camaroead 350
TH350 tranny with 2500 stall, Eibach Pro Kit, SLP 1 3/4" headers with 3" Flowmaster exhaust
Old Nov 29, 2001 | 03:36 PM
leirch's Avatar
haha, I know, i could have went further with the sanding and the 36 was a little rough but thats what I had so I made it work
if you go to 800 that should be fine.
Old Nov 30, 2001 | 02:43 PM
un4givin89's Avatar
Can someone explain wet sanding to me?
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
Old Nov 30, 2001 | 02:46 PM
cobrakiller1989's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mcconahay37:
</font>
sure, here you go
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis strut tower brace
"There is no way you have a 350 in that car. They are made to have 305's and a 350 wouldnt fit"
-local parts store genius-
Old Nov 30, 2001 | 03:16 PM
leirch's Avatar
Wet sanding is done with water(water and soap if you want, soap helps to cut better), simple get wet/dry sand paper(if you get just dry paper it will basically fall apart while wetsanding) and use water while sanding... like dip the paper in water or run water over the surface your sanding while sanding it.
Brendan
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
