January 2013 COTM **WINNER**
Old Jan 5, 2013 | 05:01 PM
JT's Avatar
JT
Community Administrator
Congratulations to IROCThe5.7L for winning January 2013's COTM!
Engine:
L98: 5.7L 350 Ci.
AFR 195 65cc Eliminator Heads
Comp Cam XR276HR-10
Holley Stealth Ram Intake
Comp Cam hardened pushrods
Comp Cam Pro Magnum 1.6 RR's
Comp Cam Lifters
Double roller timing chain
ARP bolts everywhere
Rear End:
Moser Engineering - 12 Bolt Rear
Center Section: Detroit Truetrac - 33 Spline
Gear Ratio: 3.73
Exhaust:
Hooker 2055 Ceramic Coated Headers / 3" Coated Y Pipe
3" Catco Hi-Flow Cat
3" I-Pipe
Powerstick Muffler (Medium Length)
Intake:
Polished Holley Stealth Ram
K&N's
TPiS Throttle Body Airfoil
Gutted Airbox
Ignition:
MSD 8.5mm Wires
MSD Blaster Coil
MSD Cap/Rotor
AC Delco Rapid Fire Plugs
Fuel System:
Flowmatched 32lb Ford Motorsport Fuel Injectors
Holley Adjustable Fuel Pressure Regulator
Racetronix L98 Fuel Pump Kit
-Walbro GSS340M 255L/Hr Fuel Pump
-Fuel Pump Hot Wire Upgrade Harness
Suspension/Chassis:
Spohn Sub Frame Connectors
Spohn Adjustable Panhard Bar
Spohn Crossmember Mounted Adjustable Torque Arm
Spohn Front & Rear Sway Bars
Pro Kit Lowering Springs
UMI Lower Control Arms
UMI Tubular K-member & A-arms
700r4 Transmission:
Modified Probuilt Transgo shift kit
Cooling:
160 Thermostat
Fan Switch
Throttle Body Bypass
Stewart Hi-Flow Waterpump
Braking:
Zinc coated drilled/slotted rotors all around
Hawk HPS Performance brake pads
Audio:
Sony CD Player
Kappa 693.7i 3-way 6x9 Speakers
10'' Sub
Old Jan 5, 2013 | 05:14 PM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Re: January 2013 COTM **WINNER**
That has got to be the most bad *** camaro i have seen.
Old Jan 5, 2013 | 05:41 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Congratulations
Old Jan 5, 2013 | 05:44 PM
MYFIRSTZ's Avatar
Car: 1987 IROC-Z all stock (sold)
Engine: 1987 T/A (current project)
Beautiful!! You got my vote
Old Jan 5, 2013 | 05:46 PM
skinny z's Avatar
Same paint and trim as my 2nd third gen but mine wasn't nearly as well executed.
Well done.
Old Jan 5, 2013 | 06:38 PM
LHernandezJr's Avatar
Awesome car. Congratulations, IROCThe5.7L!
Old Jan 5, 2013 | 07:42 PM
EjBaL's Avatar
Congratulations man I have admired your car for years! It is SO clean and so gorgeous and I'm only about an hour away from you. I'd love to see it sometime! You should take it to the Ellicotville car show this summer!
Old Jan 5, 2013 | 08:10 PM
iroczike's Avatar
Car: 89 camaro iroc-z
Engine: 5.7 l
Axle/Gears: 2.77 pos
Congratz the car looks amazing ive got an 89 exact same trim all original wih 35,000 miles ..and ive always wondered what it would look like if i were ever modify it .That looks like it would handle lie its on a rail. VERY NICE good luck with it..
Old Jan 5, 2013 | 08:43 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Congrats
Old Jan 5, 2013 | 08:59 PM
DD9TransAmGTA's Avatar
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Congrats on winning, I have a soft spot for black IROC's with the blue stripe.
Old Jan 6, 2013 | 12:54 PM
Slater126's Avatar
Great ride bro. You're inspiring me to spend money on mine to make it like that!
Old Jan 6, 2013 | 12:58 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Nicely done. Congratulations!
Old Jan 6, 2013 | 01:31 PM
Psychoz28's Avatar
Car: 1984 Z28 / 2002 Z06
Engine: 350 New Crate / LS6
Transmission: T5 / M12
Axle/Gears: 3.73 / 3.42
Congrats! Nice car!
Old Jan 6, 2013 | 02:38 PM
Guest
Guest
Posts: n/a
GAAAAAAAHHHHHH
Old Jan 6, 2013 | 03:19 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Congratulations! I've enjoyed your car on here for years. If I'm not mistaken, you also live in the Buffalo area. If you're up for it, I' d love to do some photos of our cars together in the summer.
Old Jan 6, 2013 | 04:19 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Very nice stance, love that car.
Old Jan 6, 2013 | 05:31 PM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
congratulations... Wish mine was this sick; someday it will be
I'm in love with your car man
Old Jan 6, 2013 | 09:15 PM
hdavis2005's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI to 305 carb
Axle/Gears: 323
Congrats my man. Beautiful ride!
Old Jan 6, 2013 | 10:14 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Awesome camaro! What size tires do you have? Also how much actually difference did the springs make?
Old Jan 7, 2013 | 07:05 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
nice car! Congratulations!
Old Jan 7, 2013 | 09:14 PM
TVIROCZ's Avatar
Car: 1987 Chevy Camaro Iroc Z
Transmission: Automatic (700R4)
Very nice, I wish mine was the same condition and had a 5.7.
Old Jan 7, 2013 | 09:34 PM
drjewalton's Avatar
Car: 1956 Chevrolet 210
Engine: Chevy 305 V8
Transmission: TH350
Axle/Gears: Posi 3.42
Congratulations on the win! Great car, man! I've always liked the black IROC's with the blue stripe.
Old Jan 8, 2013 | 08:32 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Beautiful car and well deserved! Congrats!!!
Old Jan 8, 2013 | 09:01 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Congratulations, that's one fine IROC-Z.
Old Jan 8, 2013 | 10:44 AM
David 91RS/Z28's Avatar
Amazing car!! Really really nice set up!! Well deserved win! Congrats!
Old Jan 8, 2013 | 01:49 PM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Congrats! Did you ever dyno it?
Old Jan 8, 2013 | 02:03 PM
StripedZ28's Avatar
Car: 1985 Z28 Camaro
Engine: 390CI SBC Stroker
Axle/Gears: 4.10 (Ford 9")
Well deserved! Congrats!
Old Jan 8, 2013 | 02:16 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Awesome car man! Perfect!!!!!
Old Jan 9, 2013 | 08:09 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I apologize, I never realized how nice your car is! Wow, super stealth too, bet you've surprised more than a few with that stock appearance!
Old Jan 10, 2013 | 09:47 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I have seen this car over the years and have admired it since the day I saw it. Congrats on probably one of the cleanest IROCs around! Love everything about!
Old Jan 10, 2013 | 03:28 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Thanks again guys!
I'd like to make it out. Do you go to the Olcott show?
Cool. Hopefully she's running by then.
245/50/16 I believe. The prokit lowered it 1" and it rides much better than with the stock springs.
Yea, it only made 316rwhp. The tune was off, and I let off to early. I should have strung it out to 6500rpm. But I'm building a new engine so I have no plans to keep tuning the L98.
Old Jan 11, 2013 | 02:25 AM
Nick88T5iroc's Avatar
Car: 1992 RS
Engine: Tbi 305
Axle/Gears: 3.08
Great car! I like the 12 bolt.
Old Jan 12, 2013 | 08:09 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
One version of perfection in my book, looks amazing
Old Jan 12, 2013 | 01:16 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Impressive car! Congrats!
Old Jan 12, 2013 | 03:49 PM
art91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 350 5.7 liter
Very nice looking car, congrats.
Old Jan 12, 2013 | 06:07 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Congrats mate. I've always liked this car.
Old Jan 12, 2013 | 06:15 PM
Edwardgp's Avatar
Engine: 454-350
Love the color.
Old Jan 13, 2013 | 08:06 AM
rsp13's Avatar
Car: 88 Trans am
Engine: 305tpi soon to be ls1
Transmission: t5 soon to be t56
Axle/Gears: 3.08
Very clean nice job!
Old Jan 13, 2013 | 01:38 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
IROCThe5.7L what brakes are you using on your 12bolt rear?
Old Jan 13, 2013 | 05:21 PM
Car: 1988 IROC-Z
Engine: 427 SBC
The stock 9 bolt disc's.
Old Jan 13, 2013 | 11:43 PM
yaj15's Avatar
Car: 1988 IROC-Z
Thats good. I have read for some of the aftermarket 12bolt rears you can't use the stock disk brakes. That's a significant cost savings since you can use the stock brakes.
Old Jan 14, 2013 | 01:31 PM
  #42
BADNBLK's Avatar
COTM Editor
Congrats buddy! Beautiful car.
Thanks JT for getting the pages handled while I was out of town and sick!
Old Jan 14, 2013 | 07:10 PM
  #43
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks again guys! Just going to throw these in here. Sorry I'm getting excited-lol It's almost there.
Old Jan 14, 2013 | 08:26 PM
  #44
JeremyNYR's Avatar
Car: 1984 Trans Am
Very nice! Will that intake fit under your hood?
Old Jan 15, 2013 | 12:10 AM
  #45
Car: 1988 IROC-Z
Engine: 427 SBC
Yes. Just barely. This intake was used on my L98 also.
Old Jan 15, 2013 | 01:04 AM
  #46
yaj15's Avatar
Car: 1988 IROC-Z
Thats a nice motor you are making. Do you have the specs on it? How much power and torque do you think it will make?
Old Jan 15, 2013 | 04:40 AM
  #47
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Congrats! Well deserved... Great looking Iroc you have there!
Old Jan 15, 2013 | 09:42 PM
  #48
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
.....Wanna trade?
Lol beautiful car man. I've always admired it.
Congrats on COTM
Old Jan 15, 2013 | 09:48 PM
  #49
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Beautiful!!!!! Nice stance. What products do you use on your paint?
Old Jan 18, 2013 | 11:40 PM
  #50
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Congratulations sir, gorgeous car, I've always admired it!!!!
-Paul
