View Poll Results: March COTM
68strat
5.03%
TPI-Formula350
46
25.70%
Justin89formy
7.82%
evilemokid94
2.23%
Andrew91GT
42
23.46%
mw66nova
6.15%
Lonnie P
24
13.41%
okfoz
5.03%
TTOP350
2.23%
texascat2
2.23%
Jupiter
6.70%
Voters: 179. You may not vote on this poll
March 2013 COTM **VOTING**
COTM Editor
Ok this month we had a bunch of nominations, some made the cut some didn't.
Here we go...
68strat
TPI-Formula350
Justin89Formy
evilemokid94
Andrew91Gt
mw66nova
Lonnie P
okfoz
TTOP350
texascat2
Jupiter
Here we go...
68strat
TPI-Formula350
Justin89Formy
evilemokid94
Andrew91Gt
mw66nova
Lonnie P
okfoz
TTOP350
texascat2
Jupiter
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: March 2013 COTM **VOTING**
Thanks for putting me in the running for COTM. A lot of nice cars- good luck to all... here's some pics and info on my car.
Forged 385 Stroker
1989 Formula 350....4 Bolt 385, 11:1 CR, Brodix 200IK heads,Comp 280 XFI Roller Cam(230/236 .576/.571 LSA113) Double roller timing chain, Comp Beehive springs, Comp Magnum roller lifters, Comp Magnum push rods,Comp 1:6 Full Roller Rockers, CP forged pistons,Eagle forged rods,Eagle 4340 forged crank,Custom CAI,TB bypass,Holley 52mm Throttle Body,Holley AFPR,Lingenfelter SuperRam,Edelbrock high-flo intake,30lb.FMS red top injectors, Holley 255LPH Fuel pump,Comp,Ceramic coated SLP 1 3/4" Headers,Electric Cut Out,Banks Stinger 3" Catback,1LE smog/ac delete pullies, 160* thermo,Moates GP1,Hughes 4400 stall,shift kit,LS1 aluminum Drive shaft, Nitro 3:70 gears,MSD 6AL,MSD blaster coil,PowerMaster Mini Starter,March underdrive pullies,SouthSide Machine subframe,Hothchkis 1" drop springs, Hotchkis STB, TDS Wonder bar, Founders Camber/Caster plates, Founders adjustable LCAs, Founders adjustable Panhard bar, UMI A-arms, UMI adjustable torque arm/ Cross member with DS loop, UMI LCARBs, LS1 front 1LE rear brakes, Black mesh TA rims,Mickey Thompson drag radials, 91/92 nose,cowl hood,fiberglass areo wing.467FWHP-517FWTQ. 3252lbs
Forged 385 Stroker
Engine: Cammed 6.0L LSX
You're missing the poll.
COTM Editor
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Forged 385 Stroker
http://www.youtube.com/watch?feature...&v=fU-QNICbX5A
Forged 385 Stroker
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
whew...my car does not need to be in here with some of those cars! thanks for the nominations again though!
since last year, i've swapped out the th400 and swapped in a t56. i have the 6.0 at the machine shop getting refreshened and have a junkyard 5.3 shortblock in the car at the moment. it has not been to the track since the swap.
here's a couple updated pics
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
Hey Fellas,
Appreciate the nomination, but the other cars in this thread really have it going on.
http://www.flickr.com/photos/53106660@N03/8426815041/
My car has been a constant work in progress since I purchased it two years ago, and has come a long way, and is undergoing a second transformation for this season. This car for me is to have fun on the street, with the occasional trip to the strip, but mainly just a fun, and solid cruiser.
http://www.flickr.com/photos/53106660@N03/8488296750/
http://www.flickr.com/photos/53106660@N03/7292445268/
http://www.flickr.com/photos/53106660@N03/7004801670/
http://www.flickr.com/photos/53106660@N03/7061819973/
On IROCs which I hope to go back to in 17" size, but painted VS. chrome
http://www.flickr.com/photos/53106660@N03/6437078091/
http://www.flickr.com/photos/53106660@N03/6184533595/
Before serp setup
Quick list off the top of my head:
GM Corvette replacement Target engine from the early 70s (300hp stock) .030 over running off a Holley 600 double pumper. GM Serpentine setup... Motor is being pulled however, as I have a 4 bolt 350 block to make a 383 and also a 400 block that may turn into a 434.
As it sits in these pictures for the most part:
Sunoco Hood
Hawks 5" spoiler
UMI Subframe connectors
UMI Wonder bar
Edelbrock lcas
Edelbrock adjustable Panhard bar
Eibach Pro Kit
Z28 Steering box w/ astro van steering shaft
Inland Empire Aluminum Driveshaft
10 bolt with 3.73s and a TrueTrac dif
Rebuilt T5 w/ Pro 5.0 shifter
Front end rebuild w/ Poly bushing all around
Running Corvette C5 wheels on 2" spacers
In progress for spring (car on lift torn apart):
Strange Engineering 12 bolt 3rd Gen rear end w/ 3.73s
1LE Brakes on all four corners
TKO-600 w/ adapter from Forte's parts connection
the list goes on, but that covers the basics.
Not expecting to make car of the month, but maybe I'll pop up again when the car is finished, and I really appreciate the nomination
Before serp setup
Sunoco Hood
Hawks 5" spoiler
UMI Wonder bar
Edelbrock lcas
Eibach Pro Kit
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
I really appreciate the nomination, truly not worthy.
Everthing is stock except for the wheels and sound system.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Thank you for the nomination.
I am in the middle of a total restoration / LS3 swap.
Currently the car is in pieces & will be nicer than the photos I have currently. It will not be outside for any new photos until spring
The car is a 45,000mi 91 Formula.
Brakes:
Fronts - Drilled/slotted C4HD fronts
w/ 96 Cobra Calipers (larger pistons than the Vette caliper)
Rears - 96 Trans Am rear
drilled/slotted rotors
All w/ Hawk pads
Suspension:
Front - WS6 36mm sway bar w/ urethane bushings
Global West front competition springs
Del-a-lum bushings
1/2" tall ball joints
WS6 box
Rear - 24mm sway bar w/ urethane bushings
Fays2 Watts link
Strano Springs
Brakes:
All w/ Hawk pads
Suspension:
Del-a-lum bushings
WS6 box
Fays2 Watts link
Strano Springs
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Differential - Strange 60
35 spline axles
3.54 gear
Torsen posi
Driveshaft:
Strange Engineering w/ 1350 u-joints
Transmission:
T-56 6 speed
Pro 5.0 Shifter
Hawks crossmember
Clutch:
Factory LS7
35 spline axles
3.54 gear
Torsen posi
Driveshaft:
Transmission:
T-56 6 speed
Pro 5.0 Shifter
Hawks crossmember
Clutch:
Factory LS7
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Engine:
2011 Camaro LS3 w/ 12 only miles
Custom comp cam 219/232 on 114lsa
Dual springs / titanium retainers
Fast 92 t-body
411 Computer w/ Custom tune
Urethane mounts
2008 Corvette Serpentine & all accessores including AC
Fuel system:
2002 Camaro Tank
Racetronix pump /hotwire kit in new module
LS3 injectors
Lonnies Performance fuel system w/ Billet Fuel rails, stainless braidedteflon lines w/ Fuelab filter & Fuelab regulator
Hawks 2" long tubes
3" duals into 3.5" y-pipe / exhaust
UMI frame connectors
Body:
Factory, no rust or damage
Disassembled
Stripped to bare metal
PPG Epoxy primer
Paint:
PPG urethane base/clear factory medium green
Underside black acrylic urethane
New Formula decals
Fatmat sound deadener
New headliner/carpet/factory seat covers from Hawks
All new weatherstripping
Stereo --- in progress
Double din
dual Fosgate amps - vintage punch 75 & 150
Tentative speakers - Fosgate 12" subs, Infinity Kappa 4x6 & 6x9speakers
Wiring:
Engine harness from PSI conversions
factory harness modified by myself
2002 Camaro Radiator & dual fans
Fast 92 t-body
Urethane mounts
Fuel system:
2002 Camaro Tank
LS3 injectors
Hawks 2" long tubes
Body:
Disassembled
PPG Epoxy primer
Paint:
New Formula decals
Double din
Wiring:
Car: 89 Formula 350
385 Stroker on the dyno
Been working on my suspension and brakes this winter
Rebuilt 9 bolt with 3:73s/Founders PHB
Founders LCAs
UMI A-arms, Hotchkis 1" drop springs,KYB strusts, LS1 brake conversion
LS1 Brakes
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
All i have to say is thank you guys so much, you have no idea how happy it made me to see my car nominated as there are so many better looking cars on this site and just in general. I can honestly say i never thought my car would make it into the COTM period. thank you guys again so much and good luck to all the other cars. heres a list of mods.
1986 camaro sports coupe,rust free body
originally a 2.8 v6 with auto
victory red paint
original rear 3.42 open gears
sattle bag tan interior
currently
rebuilt 350 vortec with auto
stock exhaust plus a flowmasters 80 series
z28 wheels
firebird base spoiler
new victory red paintjob
complete black interior out of a 90 RS
iroc hood
20% tint
its nothing special but its mine and iv been working on it since i was 14, im currently 18 and have come along ways from when i first got it
again i know its nothing special but its mine and im just happy i got nominated, good luck everyone and thank you guys again!!
victory red paint
currently
z28 wheels
iroc hood
20% tint
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Thank you for the nomination...this is quite a surprise!
I've been on the board for over 10 years now, just not with this name. I've had this particular car for about 11 years now. I got it when I was living in upstate NY. I had just sold my Sports Coupe that a friend and I built which had a 406 and th350 and other goodies in it. I felt sellers remorse so I immediately started searching for something else. I got this formula for about $2800 in very good condition, but with a blown motor. The reason I paid so much is because it was a Florida car and there was NO rust which is a huge issue in the northeast. I've had a plan in my head for a thirdgen ever since I was 15. I'm just now realizing that I'm finished my plan
I've been through about 4 different engines, 2 transmissions and 4 axles. I've also had 3 sets of wheels on the car. It's never "done"
Here is a breakdown of my car
BODY:
-Fresh "down to the metal" repaint.
-ASCD Ram Air 1 hood
-Hawks repro spoiler
-Stripe delete
-tasteful decal delete
Chassis/Suspension/Driveline
-Dana 44 with 4.11 gears
-4th Gen aluminum drive shaft
-T-56 with Pro 5.0 shifter
-MacLeod clutch
-Poly bushings throughout
-Spohn LCA, LCARB, Panhard, Subframe connector, solid strut mounts. TDS Wonderbar. Custom UMI Strut Tower Brace
-36mm WS6 front sway bar, 24mm WS6 rear sway ba4
-Bilstien AK Struts/Shocks
-Eibach Pro Kit lowering springs
-17" Ronal Firehawk wheels with 275-40-17 on all 4 corners
-LS1 Front brakes. LT1 rear brakes.
Engine/Etc.
-355 Gen1 SBC 4 bolt
-Scat forged crank (3.75")
-Polished X Beam rods
-SRP forged pistons
-AFR Eliminator 195 heads
-TPIS Miniram
-30 pound injectors
-Lloyd Elliot custom cam 223 230 .535 .535 109LSA
-OBD2 PCM swap using stock GM Electronics
-Dyno Don headers and Y Pipe. Magnaflow 3" Catalytic Converter, Magnaflow catback
-Champion 3 core aliminum Rad
-Chassis dynoed 370 RWTQ, 370 RWHP
-1983 Charcoal grey interior pulled from a NEW car that was converted into a race car. An amazing find since its pretty rare to find in good shape!
-New headliner, carpet and 4thgen cloth seats
-145 MPH speedo with MacEwen white face gauges
-Triple A-pillar gauge pod with Autometer Wide band O2, Fuel Pressure, and water temp (all electric)
Here are some videos
Idle clip: (Pre paint)
Burnout: (the day the Dana went in. Had to prove the old posi worked to the buyer of the 9 bolt
Paint:
The teardown...so sad
Mocking up the new spoiler
Here is the car in June on the Hot Rod Power Tour
with TTOP350
Next few are in Route 66. I'd always wanted to travel route 66 in my car, and it just happened to be my birthday....it was amazing!
My car in front of an old Route 66 gas station.
Thanks again for your consideration!
BODY:
-Stripe delete
-MacLeod clutch
Engine/Etc.
-SRP forged pistons
-TPIS Miniram
-30 pound injectors
)Paint:
with TTOP350
COTM Editor
Some amazing rides here this month! WOW!!!
okfoz has the sexiest wheels IMO
Car: 1986 IROC-Z
Axle/Gears: 4:10
Wow - Lots of votes for just opening the voting.
Great cars here! Lonnie P has my vote! I can't wait to see this car finished. I love the color.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Man this is a toughy... I am undecided between 3 of em' .. Nice cars guys
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
I'm not sure i belong on here YET but thanks. This $300 car was given to me as junk and became my daily driver from 1996-2001 after a little bit of work. It then sat in storage till 2010. It has taken me the past 3 years to do all this on a VERY thin shoe string budget.
4 bolt 383 all forged lower end
full roller lunati cam kit
trick flo 2.02 aluminum heads
performer rpm manifold + 1" spacer
demon 750
RobbMc fuel pump
k&n air filter
msd dizzy+6al
hooker shorties to 3" with no cat to flowmaster with 2.5" tips
serpentine conversion
electric cooling fan conversion
4th gen coolant bottle conversion
1996 t56
hurst competition plus shifter
ram clutch
spec billet steel flywheel
3" coleman aluminum driveshaft
10 bolt 4th gen disc rear with aftermarket auburn posi 3.42 with moser axles, c-clip eliminators and perfect launch girdle
iroc wonder bar
36MM hollow front sway bar
24mm rear sway bar
energy suspension motor mounts and bushings everywhere
custom moog springs with 1" drop
kyb agx adjustable struts/shocks
pbr brakes
granatelli lca's
founders lcarb
spohn panhard
spohn torque arm/trans mount
south side machine shop frame rails
edlbrock strut tower brace
j&m strut mounts
ram air fiberglass hood
89 gta 140mph/8k rpm dash console and converted interior from grey to black but kept the factory electric pmd seats 'recovered'
added power locks, mirrors, hatch, vanity mirror, cargo door
daytime running lights module
dakota digital sgi-5c vss converter
c5 wheels
Recently i did the t56 conversion and while i was at it i stripped the undercarriage. With the car on jack stands and me laying on the ground turning my back into hamaburger meet i scraped, sanded and, scrubbed it bare. Re-sprayed it with undercoating and painted all the bolts and brackets. I cleaned up the fuel and brake lines with a wire brush on my drill then rubbed them down with steel wool to make them shinny again. Painted the tranny and exhaust with vht flame proof header paint.
Next on the list to be done is to get some new seat belts and nicer shifter boot and **** so as to finish the interior, ls1 brakes then finally getting it painted again
So after getting it painted and cleaning it up back when it was a daily driver in the 90's
Moving on to the modern era
demon 750
RobbMc fuel pump
k&n air filter
msd dizzy+6al
1996 t56
ram clutch
iroc wonder bar
24mm rear sway bar
pbr brakes
granatelli lca's
founders lcarb
spohn panhard
j&m strut mounts
c5 wheels
Car: 1991 red Z/28
Transmission: T5 swap
It took me a little time to vote this month becasue there are some very awesome cars and as far I am concerned they are all winners. But there can only be one COTM. Jupiter, your interior got me so I voted for you.
Car: 82 Trans Am
Engine: 383
Thanks guys. The undercarriage makeover was less then $100 in cleaning and paint material BUT brutal on my back, fingers, angle grinder and, killed my drill i used with wire brush... lol
Car: '18 Jeep Wrangler, '19 Honda Accord
Engine: 2.0T in both
Transmission: 8 speed auto, 10 speed auto.
Thank you SpeedDemon91, yes, that's his car. It looks great up close and sounds even better!
Cool! A little trick I use is flatten a large cardboard box to lay on. Much easier to slide around on!
Car: 82 Trans Am
Engine: 383
A scrapper a wire brush, a gallon of degreaser and, some thinner and i ruined my cardboard bed. In the end i didn't really mind. Sanding was easy once it was all clean.
Car: 83Z28 HO
Transmission: G Force 5 speed
Wished I could've voted for 2 or three of those cars!!
Seriously nice rides....all of them.
Engine: 4++,350 & 305 CIs
TTOP350
Wow, some truly great cars here. Thanx for the nod.
Car: 1992 Chevy Z28 - Black
Engine: ZZ4 350 HSR w/ 100 shot
Transmission: Automatic - Hurst dual gate
Axle/Gears: Moser 12 bolt 3.42 Eaton gears
Eric you got my vote early,
Car: 91 Firebird
Engine: H/C 6.0 LQ4
Transmission: RPM T-56
Axle/Gears: Moser 12 Bolt w/3.73s
All nice cars this month! Love the formulas. My vote's in.
COTM Editor
Well all the votes are in and the poll is closed! Congrats to TPI-Formula350
Thirdgen89GTA
Nov 26, 2015 11:04 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Linson
Oct 1, 2015 09:50 PM
Linson
Sep 21, 2015 01:08 PM
