To wrap or not to wrap
Car: 89 trans am and 78 y88 trans am
Re: To wrap or not to wrap
that is not my car. i have one like it i was thinking of wrapping. the picture was one i found that had been wrapped. I have seen that car before and it was painted black and think it was from germany
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Thanks, I did not do the door jambs since that's a little more involved.
Car: 1989 Camaro Rs
Engine: 350 TBI
Axle/Gears: 3.73 Posi
Is there a seam on the top of your car, in front of the rear hatch?
Just trying to figure out how you might have done it haha.
Awesome car by the way.
I did the rear body portion in 3 sections. The seams are right behind the outside portion of the t-tops right when the body curves downward. I could've gone a couple of other ways with that but decided to do it that way. I used 3m satin black vinyl and 3m carbon fiber vinyl for the hood, solarwing and top portion of the rear wing. I just did the wing over the weekend. Everything is holding up just fine. This stuff lasts for years just like a regular paint job.
Attachment 343899
Attachment 343899
I just laid the vinyl over it and cut right at the upper portion of the opening and followed it around the contour. I sprayed the inside of the opening flat black before I wrapped it.
Car: 90 Camaro RS
Engine: 5.0 TBI
Check out the finished product. I'll wrap the solarwing later on.
Attachment 350742
Attachment 350743
Attachment 350744
Attachment 350742
Attachment 350743
Attachment 350744
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
i will be wrapping my Camaro this year but the headlight pockets look like a pita with how deep they are any suggestions on them?
I think the best bet for that headlight inlet is using knifeless tape on the edge of it. There will be a seam, but that's probably the most ideal way to do it
Why not actually PAINT the pocket? Or plasti-dip? Lord knows I despise plastidip, but in this case... ...I think the main body needs a little different finish than the headlight pocket anyway.
i wasn't thinking about the knifeless tape for the headlight pocket and i think that will do the trick. i plan on doing metallic silver, black headlight pockets, and i have a set of red 91/92 z28 stripes.
Here's the first episode for my third gen series on youtube. Stay tuned. I'm about 8 episodes in and here in a few episodes I should be starting to do the vinyl
Eric-86sc
Feb 25, 2016 09:02 PM
