detailing tip
Old Dec 10, 2001 | 02:52 AM
nagga's Avatar
detailing tip
not sure if any of u have heard of Red Hot (Red Hawk now) and Orange power, Red Hot is a detailers best friend, it will take just about anything off, its a really good cleaner, i dont think that u will find it in a store, u have to order it, but i recomend using this on your washer and coolant tanks, and use orange power all around your engine bay, let it soak and spray it off, also if u spray your car down with orange power and let it settle for a bit it will make your paint really smooth, then mix some redhot with your carwash and it makes the paint even better, when using red hot mix 50-50 with water, and u will need a heavy duty sprayer to hold up for the red hot, but u should have seen my wheels, they had years of road grime, havent been washed for prolly years, and had oil on them, i sprayed with red hot and scrubbed with a tire brush, they look almost new, trust me, u will have more than just one use for this stuff, but it is the best cleaner i have ever used
Old Dec 10, 2001 | 07:48 AM
92RSB4C's Avatar
Where do we get it?
Old Dec 10, 2001 | 04:57 PM
nagga's Avatar
u have to order it from somewhere, i can find out
Old Dec 10, 2001 | 05:15 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Red Hot will stain paint, and anything that can be stained. I haven't heard of "Red Hawk", but our distributor now sells "Red line". That stuff isn't as good as Red Hot was in cleaning the interior, but will also stain stuff. Make sure that if you have some overspray, you IMEDIATELY wipe it off. And don't spray it directly on vinyl or leather, or plastic. First spray it on a rag, then wipe the surface.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Linson
Oct 24, 2025 02:00 PM
Thaney9
Oct 15, 2015 06:37 AM
Linson
Oct 1, 2015 09:50 PM
Night rider327
Sep 25, 2015 04:47 AM
