Cleaning washer/coolant tank ?
Old Dec 11, 2001 | 09:28 AM
Swede's Avatar
Anyone got a tips on how to make these tanks clean. both inside the and outside looks like sh...
Z28 -87 TPI
white with T-roof
red interior with leather seats
Wagner Borg rear axel
all options
all stock
check Website for info.
www.musikhuset.org/~po/camaro
Old Dec 11, 2001 | 10:40 AM
Drew's Avatar
Its pretty easy but it'll cost you about $30. Go to any GM dealer, and order new ones. Once they turn yellow they're stained forever. You can try any chemical you want and they'll still look trashy.
Drew
predatorman@hotmail.com
83 Camaro 5.0L *1995-98*
87 Iroc 5.7L
91 Formula 5.7L 14.3@98mph
91 RS Convertible 5.0L
91 Firebird 3.1L 17.00@82mph *Gtech*
92 S10 2.8L
98 Grand Am GT 3100
Parts for sale
Old Dec 11, 2001 | 10:47 AM
Mirsiro427's Avatar
The outside is easy, just scrub it till it looks good. Start by removing the tank. Then I put about two cups of fresh walnut shell blasting media into the tank with a stong soap/water solution (fill to about a quarter full). I then put a rubber stopper into the hole on top and plugged the hose outlet. The next step is to shake it like you've never shaken anything in you life. The walnut shell media does a really good job of scrubbing the inside surface of the tank without doing any damage. The soap I used was an industrial parts cleaning detergent that is known only as "blue soap" around here (where I work). I'd suggest using Simple Green or maybe that purple stuff.
EDIT: Like Drew said, if the tank/s are yellowed, nothing will save them. Mine were in pretty good shape, just dirty.
[This message has been edited by Mirsiro427 (edited December 11, 2001).]
Old Dec 11, 2001 | 11:52 AM
Swede's Avatar
Ok... Seems like´I´m better of to buy me new ones then..
Big thanks for the responses guys :-)
Z28 -87 TPI
white with T-roof
all options
all stock
Old Dec 11, 2001 | 09:07 PM
breathment's Avatar
what if u wanted to paint them?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake, and an Energy Suspension Poly trans mount that is worse then the broken rubber tranny mount
http://www.geocities.com/david_angel_16
Old Dec 12, 2001 | 04:06 PM
GreenProStreet's Avatar
Paint 'em, but leave a sight so you know how much fluid there is.
Colin Finkle
'87 Camaro SC
Bohemian
Aug 15, 2017 05:11 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Strick1
Sep 6, 2015 10:38 AM
Glowsock
Sep 5, 2015 07:48 PM
86iroczwv
Sep 3, 2015 06:21 PM
