A new spin on the Coolant Overflow relocation
Old Oct 26, 2013 | 10:01 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Hi all,
I've seen the threads on using the 4th gen coolant overflow tank, but that won't work with the stock GTA airbox, which I didn't want to move/modify. Since I'm not running a charcoal canister, I wanted something that would work in that location. The answer came from Dorman, who sells a universal overflow tank under part number 603-001.
Due to the size limitations, I didn't want to use the nipple that was sticking straight out of the bottom of the reservoir, so I cut that off and inserted a concoction that I put together from the plumbing isle at Home Depot. I wanted a 1 piece 90* fitting that was threaded on one end and had a 3/8 slip-on hose fitting on the other end, but Home Depot didn't have any. Of course, after I finished this project, I found exactly what I was looking for somewhere else, but I digress. I wound up using a 3/8 elbow, a pipe-thread to slip on hose fitting adapter, and used a 3/8 to 1/2" pipe adapter that I cut the threads off of to use as a nut.
Here's a picture of the parts:
Here's the stuff all installed. On the inside I used RTV sealant to ensure that the tank doesn't leak:
Here's the passenger side area where the airbox and the tank go:
Here it is with the lower airbox/smog pump mount installed:
Here's the air filter housing and the tank set into place for pre-fitment:
I drilled 2 holes in the fender support and used the removable-style plastic fasteners:
Here's a pic from another angle:
Added a new 3/8" line from the radiator to the bottom of the tank and it's all done:
In case you were wondering, the stock overflow tank cap fits the new bottle perfectly, so it winds up making a very stock-appearing installation that is completely reversible in case the car ever needs to have the charcoal canister put back in.
Old Oct 26, 2013 | 11:10 AM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Re: A new spin on the Coolant Overflow relocation
Nice job! I really think that is a great idea!
Old Oct 26, 2013 | 11:18 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Very neat. Job well done.
Old Oct 27, 2013 | 02:25 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I used the smaller one from Vatozone and hide it under the cover in front of the radiator. Loks good.
Old Oct 27, 2013 | 07:25 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Very nice and clean
Old Oct 27, 2013 | 07:51 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Looks great Jim. very nice stock appearing touch.
Old Oct 27, 2013 | 07:58 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
That's a slick idea. Here is how I did mine a couple years back, when I switched to a single plane efi.
Old Oct 28, 2013 | 01:20 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I might have to do this over the winter as I plan on making a turbo kit for the car and will need to move the battery and 4th gen bottle im sure of it
Old Oct 31, 2013 | 11:52 AM
89blues's Avatar
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
Did you have to make that bracket that mounts over the rad?
sheachopper
Jul 31, 2019 11:27 AM
meeklay812
Oct 1, 2015 03:46 PM
