headlights
Old Apr 22, 2014 | 08:23 AM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
headlights
guys in the process of completing my car and I want to put on a set of factory looking headlights, i was going to go with the clear ones but I want the factory look to match the fog lights etc.
anyone aware of a set of factory style headlight that offers a replaceable bulb instead of a sealed beam... or if you have any other recommendations.... havent been around here much lately, did a search and the most recent post i found was from 2001 lol
Old Apr 22, 2014 | 08:24 AM
IROCNParts's Avatar
Re: headlights
thanks for the help
Old Apr 22, 2014 | 12:44 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Re: headlights
You can open those with a razor blade and a couple of screw drivers the toss in the bulb you want in and seal it back up with a little caulking
Old Apr 22, 2014 | 01:42 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: headlights
For headlight housings with a factory appearance and the light source of your choosing(aftermarket Halogen/Xenon Plasma style bulbs, HID kit or LED kit), offering the versatility of being able to swap to or from any of those light sources in the future, these Autopal 4x6 E-Code housings will probably be your best option.
http://www.tlg-auto.com/autopal-4x6-...ce-headlights/
Search the website in the above link for more 4x6 options. Also search ebay. From simple to complex, entry-level to high-end, you'll find a lot of 4x6 options available.
Old Apr 22, 2014 | 11:06 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Re: headlights
search hawks thirdgenparts.com they offer a 4x6 that looks stock and can use an hid bulb they sell the entire kit with bulbs and ballast for 150
Old Apr 23, 2014 | 01:21 AM
IROCNParts's Avatar
Re: headlights
Perfect! Got a set for $60! Thanks guys!
Old Apr 23, 2014 | 08:02 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
Re: headlights
I know you already got a set, however one thing I noticed that some one else had swapped in were a pair of chevy celebrity headlights, I do not believe they are sealed beam so that someone could put in HID's
Old Apr 24, 2014 | 08:07 AM
IROCNParts's Avatar
Re: headlights
Ya I would be interested In doing something different but until they make a set of fog light lenses to match I'll keep a stock look
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
