The end of an era..or is it?
Old Jan 28, 2015 | 04:03 PM
  #101
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: The end of an era..or is it?
I just emailed the company that makes them to see if they still make them for the GM cars. Upon some more research, it seems Torsen was bought out back in 2003 by another company JTEKT who now makes them.
Old Jan 29, 2015 | 04:48 PM
  #102
karl's-92'-z28's Avatar
Car: Too many cars
What did you use to paint the engine bay & where did you get the plenum cover from?
Old Jan 30, 2015 | 10:01 AM
  #103
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I had it custom made. I bought 1/4" aluminum and took it to a machine shop along with the original so they can get the dimensions correct
Old Jan 30, 2015 | 10:03 AM
  #104
pwdbychevy's Avatar
Originally Posted by Bob88GTA
Swageloc is awesome! We use them on alot of our rocket engine assembly's.
AN is fine, are those aluminum, right?
If you mean the an fittings then yes they're aluminum.
Old Jan 30, 2015 | 10:08 AM
  #105
pwdbychevy's Avatar
Originally Posted by Ozz1967
Ok, I feel dumb. I read through the entire thread and missed that.
I have basically his exact rear-end, welded axle tubes, 28 spline moser axles, 3.73's and the 'Ultimate" diff cover, but a zexel torsen instead of an auburn unit. If a solid pinon spacer makes that much difference, I'm going to kick myself because I had one that I couldn't find when I needed to rebuild the rear end so it didn't get installed and the guy at the shop swore up and down I wouldn't need it.
IMHO I think a solid spacer is easier to setup because you don't have a crush sleeve to preload and if you preload a crush sleeve too much then it's ruined and you have to get another. With a solid spacer kit all you do is torque it and go. Solid spacer setup prevents the pinion gear from riding up the ring gear which causes wear and tear and eventual gear failure.
Old Jan 31, 2015 | 12:27 AM
  #106
Ozz1967's Avatar
Car: 1984 Trans Am
Thanks for info on that. I may swap out the 3.73 for a 3.42 the next time it needs a rebuild and even if I don't swap gears, I'm going to put that solid spacer in, especially seeing how it's helped your rear end hold up to 700HP for so long. That's really all any of us with a 10-bolt can hope for.
Old Jan 31, 2015 | 07:45 AM
  #107
pwdbychevy's Avatar
The rearend should survive with street tires and stock clutch but I still wouldn't trust it with drag slicks and 5k rpm clutch dumps
Old Feb 20, 2015 | 05:34 AM
  #108
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Xxr531's
The entire car will be wrapped in black brushed aluminum vinyl by yours truly :-D
I'm digging the wheels nice to see them and good use damn the look good
Old Feb 20, 2015 | 05:21 PM
  #109
pwdbychevy's Avatar
Thanks Zach and thanks for the awesome deal on them
Old Feb 20, 2015 | 07:31 PM
  #110
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Are those wheels a direct bolt on?
Old Feb 20, 2015 | 07:38 PM
  #111
Engine: 305 to 350
Axle/Gears: 10 Bolt
Engine looks gorgeous i would eat off it lol decided on vinyl yet Im on my way to pick up badass set of wheel right now that I'm settle for finally lol
Keep it up glad you like them can't wait to see final product looks 10 times nicer then my milk bucket
Are they bolt on answer is no but doesn't take much to fit they do offer a 19" that will fit better
Old Feb 21, 2015 | 05:10 AM
  #112
pwdbychevy's Avatar
Yeah I'm going with the black aluminum vinyl wrap. What kind of wheels have you settled on? I want to have the rear wheels redrilled like you did the fronts to tuck that rear sidewall in a little more.
Old Feb 21, 2015 | 11:55 AM
  #113
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea that's what I was going to do but never came around to it , I'm sure there's some place in Florida that can do it
Excuse the dirty car trans pump went south had to rebuild and put back in myself def not no easy task my body still aches lol but I'm wrapping up my LSX swap I'm tuning her now
Old Feb 21, 2015 | 12:04 PM
  #114
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Wow, nice!
Old Feb 21, 2015 | 12:06 PM
  #115
gsmarcano's Avatar
Car: Camaro
engine **** man.
Old Feb 22, 2015 | 07:22 AM
  #116
pwdbychevy's Avatar
Those look bad ***! HRE?
Old Feb 22, 2015 | 10:18 AM
  #117
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea lol I got lucky
Old Feb 22, 2015 | 02:26 PM
  #118
357 Camaro's Avatar
Car: 92 camaro/99 gmc Z71
Engine: 357/5.3
Transmission: built 700r4 4500 stall/4l60
Axle/Gears: 4.56/?
Was sad to see what happen to you car. It seems ur making the best out of the situation/ Good job man the car is looking amazing.
Old Mar 31, 2015 | 07:32 AM
  #119
pwdbychevy's Avatar
Ok yall here's a quick update. THE BEAST IS ALIVE!! I fired her up over the weekend and it purrs like a kitten. I'll post video later but here are a few pics taken yesterday.
Old Apr 17, 2015 | 03:10 PM
  #120
82IMSA's Avatar
Car: 1986 Camaro IROC Z28
Engine: LS7
Transmission: Built 4L80e w/GearVendors overdrive
I didn't read the entire thread, so sorry if I missed this, but I love that wing on your wrecked car (looks just like the one I had on my old '82 Firebird) and would love to have it for the '86 Camaro project I'm starting. Is it available?
Also, saw you make top notch clear light covers that won't fly off. Are you still doing that? Need some for an '86 Camaro IROC Z28.
BTW, very nice build on the new car. Can't wait to see how it comes out.
Most of the drive train is being swapped over to the other car so yeah she'll live on in spirit definitely :-)
Old Apr 17, 2015 | 04:08 PM
  #121
Ozz1967's Avatar
Car: 1984 Trans Am
Well it's been a while since ive been on here so i figured I'd post up on what's happened. A couple months ago I was to start a 406ci Dart SHP with a T76 turbo build. I figured I'd go for a cruise with my friends for one last weekend before I started tearing down the car. On my way back home some a-hole pulls out in front of me like I wasnt even there. I slam on the brakes and the car spun out of control into a guardrail doing 75mph. This was the end result. A Camaro that I've had for 22 years original owner purchased in Germany is totaled. Here is the carnage.
Engine still ran believe it or not
I even drove it onto the trailer but had to put the front left wheel on a dolly to do so.
I just looked back through this thread and great job on getting the new car to where it is today. It looks fantastic.
Just a question though, about the original car, what spoiler is that? I really dig it.
Old Apr 17, 2015 | 05:04 PM
  #122
82IMSA's Avatar
Engine: LS7
The wing is a Turbo II made by ASCD, but I don't think they make them anymore. It is the same as what I had on my '82 Firebird.
BTW, you can get a similar look by buying a Fiero GT wing.
Old Apr 17, 2015 | 05:05 PM
  #123
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Sweet build. Sorry about the other. R.I.P thought, you should pull off your plenum cover and have a shop machine something cool in it. Seems like a great spot for something. maybe a memorial for your other z.... or maybe you just want to plain forget that happened. The saying is true, When one door closes....2 more open. What kind of H.p you planning to get out of the new car? Keep them posts coming!!!
Old Apr 17, 2015 | 09:10 PM
  #124
pwdbychevy's Avatar
Thanks, I still have that wing hanging in my garage. I think I want to keep it as a memento of the first modification I ever did to that car the 22 years Ive owned it. If I decide to sell i'll let you know. I don't make those covers anymore. Too time consuming and I have alot going on with this current car.
Yeah the plenum cover does look bare. I was thinking maybe taping a design on it and sandblasting it afterwards. HP rating I'm hoping to get around 700rwhp or more. This is a starter turbo with a small .81ar exhaust so that will definitely limit my HP numbers. The engine itself will handle over 1000hp so all I really need is a turbo upgrade to reach those numbers.
Old Apr 17, 2015 | 09:40 PM
  #125
82IMSA's Avatar
Engine: LS7
Thanks for the response. I understand. If you change your mind, I really, really want it ($$$)
After I posted I noticed some posts where you said you had plans/instructions for the light covers, could you PM them to me?
Old Apr 17, 2015 | 09:43 PM
  #126
pwdbychevy's Avatar
I'll have to dig them up. They're in an old computer sitting in the closet. They were instructions on how to install the covers.
Old Apr 18, 2015 | 12:33 AM
  #127
Ozz1967's Avatar
Car: 1984 Trans Am
How would it look on a TA I wonder? I just love how it looks.
Old Apr 18, 2015 | 03:39 PM
  #128
82IMSA's Avatar
Engine: LS7
This is how it looked on my '82 Firebird with the Product Guild IMSA Kelly kit.
Anybody know where I can find the all aluminum louvers like I had on the old car?
Old Apr 18, 2015 | 04:26 PM
  #129
Ozz1967's Avatar
Car: 1984 Trans Am
Attachment 291097
That's a good looking car.
Old Apr 18, 2015 | 09:09 PM
  #130
82IMSA's Avatar
Engine: LS7
Thanks, it was. I wish I could find it, but the last title transfer was when I sold it in 1991, and it hasn't been registered since 1996, so I'm assuming it's been scrapped.
Old Jun 23, 2015 | 10:27 AM
  #131
pwdbychevy's Avatar
Ok yall, i havent updated in a while so im just gonna leave this here Car is wrapped and almost done. Video of the test drive
Old Jun 23, 2015 | 04:51 PM
  #132
Engine: 305 to 350
Axle/Gears: 10 Bolt
oh cant wait to get into lsx boost action
clean car
Old Jun 23, 2015 | 06:10 PM
  #133
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Sounds and looks good!
Just me nit picking but I would have liked to see the front wheel pushed out a 1/2" or so, so it protruded as much as the rears do. Other than that is a beautiful car. Get some shots of the inside.
Old Jun 23, 2015 | 08:07 PM
  #134
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Inspirational!
If a pic is worth a thousand words, that vid is worth a million words. Nice work.
Old Jun 23, 2015 | 09:52 PM
  #135
pwdbychevy's Avatar
Originally Posted by UltRoadWarrior9
Inspirational!
Thanks, it was alot of work but it's paying off.
Old Jun 23, 2015 | 09:53 PM
  #136
pwdbychevy's Avatar
The interior is next.
Old Jun 24, 2015 | 12:15 AM
  #137
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
Originally Posted by bigdavesiroc
so, so sorry for you. what a sad day...makes me want to go hug my car.
makes me not want to drive my T/A for fear of that happening... I even have the wife follow me when I take it work for oil change so i lessen the chance of driver not paying attention and getting rearended......I'll throw extra coat of wax on her this weekend.....RIP
Old Aug 4, 2015 | 11:08 AM
  #138
J. Chris Davis's Avatar
Oh wow. I didn't know this had happened. Sorry to hear about the Camaro, but nice to see you almost have its replacement done.
J-money
Jan 4, 2019 09:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 7, 2015 09:41 AM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
