**Painting Engine Bay**
Old Sep 19, 2015 | 08:14 PM
Drone358's Avatar
Hi guys,
Just curious what paint has worked well with any of you. I want to do a flat black right before install the engine. (where im at now) And is there anything I should prep the engine bay with and clean with specifically before the painting?
Thanks guys
Old Sep 21, 2015 | 02:41 AM
ronchic's Avatar
Car: 1986 firebird
Engine: 305 v8
Transmission: auto
Axle/Gears: 2.73 ?
Re: **Painting Engine Bay**
satin black would be better then flat !
Old Sep 21, 2015 | 02:59 AM
Twin_Turbo's Avatar
nothing wrong with flat black
Old Sep 21, 2015 | 05:41 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Make sure to pre clean the hell out of it. Over the years, oils and anything with silicone has probably been all over the engine bay. Pre clean, pre clean, and pre clean, that way you have no fish eyes once you spray
Old Sep 21, 2015 | 06:53 PM
Drone358's Avatar
Yeah for sure, ok thanks man. I'm gonna use a engine degreaser to clean it. Then scrub it with scotch Brite or 300 count sand paper to roughing the surface up. Then, wipe with alcohol to dry it out. After all that I'll paint it!
Old Sep 21, 2015 | 06:54 PM
Drone358's Avatar
Damn, that looks good man!
Old Sep 21, 2015 | 08:54 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Cleaning is the worst part, but also the most important as mentioned earlier. I used Valspar's Tractor and Implement paint with no clear coat in my engine bay. I used the satin black, not sure if they have an actual flat black. I know it's not an "automotive paint" but it's much tougher and resistant to chips and scratches. I dropped wrenches and sockets several times while putting everything back in and they didn't leave any marks.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
