Wet sanding to restore park light & tail light housing's
Old Sep 16, 2016 | 05:45 AM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Park light housing one before wet sanding and waxing the other after wet sanding and waxing.
I decided to try restoring my 91 RS Convertible's park light housing's by wet sanding. Held park light in vise and used electric dancer with 320, 400, 600, 1000, 1500, 3000 & 5000 grit paper - all wet sanded. Washed, dryer and waxed.
I was happy with the out come and it saved a few dollars compared to buying new ones.
Also used the same process on the tail light housing's.
Old Sep 16, 2016 | 05:47 AM
Re: Wet sanding to restore park light & tail light housing's
End result for tail light housing.
Old Sep 16, 2016 | 07:12 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Those 3M headlight lens restore kits work wonders on a drill as well.
Looks good man.
Old Sep 16, 2016 | 07:18 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I saw a "Chris FixIt" video where he wet sanded his PT Cruizer's headlights, then used a Rustoleum Gloss Clear for Plastics, that prevented oxidation & UV protection, and 2 years later, the lights still looked good... He sprayed 2 or 3 coats of that stuff on them after wet sanding them...
Old Sep 16, 2016 | 01:20 PM
I will keep Rustoleum Gloss Clear in mind next time I'm doing something like this. Thank you for the tip.
Top is before and bottom is after refinishing.
Old Sep 16, 2016 | 01:23 PM
luvofjah's Avatar
Nice, you can really tell on the white reverse lens, where all the yellow is gone...
Yeah, I've seen other "refinish lights" and the Rustoleum Clear Gloss for Plastics seemed to do the job to seal and UV protection...
Rafael
Tibo
Exterior Parts for Sale
Sep 25, 2016 01:13 PM
Z28Johnny
Sep 16, 2016 05:26 PM
bubbaz28
Carburetors
Sep 15, 2016 02:24 PM
subedriver
Exterior Parts Wanted
Sep 14, 2016 03:09 PM
instro84
Interior Parts Wanted
Sep 14, 2016 08:28 AM
