Well.. need an inspection sticker...
Old Sep 26, 2018 | 12:39 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
So this has to happen..
My buddy does inspections but because of the cameras the old front plate is going back on to the old grille.. gonna do a temporary grille swap..
Old Sep 26, 2018 | 02:40 PM
Axle/Gears: G80 GU2
Re: Well.. need an inspection sticker...
Mission accomplished!
Old Sep 26, 2018 | 03:01 PM
Abubaca's Avatar
So what exactly is this inspection sticker thing you speak of!? LOL.....j/k North Carolina for the win baby!!!!!!!!!!!
Old Sep 26, 2018 | 03:46 PM
Axle/Gears: G80 GU2
no inspections!?
Old Sep 26, 2018 | 03:58 PM
GASPEDDLER's Avatar
I switch grilles as well when I want to display a plate at car shows. By the way no inspections in Texas when you run antique plates.
Old Sep 26, 2018 | 04:02 PM
Axle/Gears: G80 GU2
You guys are lucky!
Why do you like to have a plate on there sometimes? You like to show the old “Heartbeat” plate like a dealership would have?
I think it looks very period correct with the Heartbeat plate..
Old Sep 26, 2018 | 04:16 PM
GASPEDDLER's Avatar
Originally Posted by 88IROCvertZ
You guys are lucky!
Exactly, I like to run a "USA1" plate at a couple of on base air shows and at VA car shows that I display my car at throughout the year.
Old Sep 26, 2018 | 07:06 PM
Axle/Gears: G80 GU2
That’s classy.. I like the USA 1 plates
Old Sep 26, 2018 | 08:35 PM
Abubaca's Avatar
We have inspections officially, but OBD1 stuff is basically pull up, walk in, pay the nice lady, walk out.
Old Sep 26, 2018 | 08:53 PM
Axle/Gears: G80 GU2
that’s what I did today.. just have to have a front plate for the cameras the state put in..
Old Sep 26, 2018 | 09:53 PM
SteelDirigible's Avatar
Car: 84 Berlinetta
Engine: LR4
No front plates or inspections in KY
Old Sep 26, 2018 | 09:57 PM
Axle/Gears: G80 GU2
must be nice!!
Axle/Gears: G80 GU2
At least I don’t have emissions anymore..
Old Sep 27, 2018 | 11:34 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
So won't you get a ticket from the first police officer or camera that notices? Have you looked into collector insurance with a mileage restriction? Some states allow that and it let's you forego emissions and any inspection.
Old Sep 27, 2018 | 03:02 PM
Axle/Gears: G80 GU2
Mass probably won’t allow no safety inspection and they are maniacs about having two plates.
They have a year of manufacture form for RMV and you can put classic plates on except for the 80s green letter plates because in the 80s there was only a rear plate..
The reasoning is because of the new automatic tolls that use your front plate to send you a bill..
If I have an eZpass transponder that should suffice, but yes typically they can give you a ticket..
My play would be:
”Just got the car painted and a new grille put on, there’s no holes for a plate”
”Car gets driven 1000-1500 Miles/year to shows and cruise nights only”
Then I would install the plate with the old grille, snap photos, and they’ll let you off in court if you comply quickly..
At that point I guess I’d have to run a front plate.. maybe be a grille swapper like Arnold..
Old Sep 27, 2018 | 07:31 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
No inspections in FL either!!
Since I'm hating this Ford F150 I bought, I'm thinking about putting my USA-1 plate on the front. That should **** off the Ford faithful. BTW, I'm also thinking about getting a vinyl sticker for the tailgate that says, "I wish I was driving a Chevy"
Old Sep 27, 2018 | 11:09 PM
Axle/Gears: G80 GU2
ha ha! That would be a sight!
Your Ford rant on that other thread was classic!
Old Sep 27, 2018 | 11:33 PM
the_assman's Avatar
Car: 90 vert
i'm getting ready to go through this same scenario , VA requires a front plate. i don't really want to drill holes in my grill or bumper and don't have a spare grill so i used some neodymium magnets to mount the front plate. pops off and goes back on in seconds
Old Sep 27, 2018 | 11:43 PM
Axle/Gears: G80 GU2
Great Idea
Old Oct 1, 2018 | 09:27 AM
91chevyz28's Avatar
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
In NJ, no more inspections for vehicles 95 and older. Only 96 and newer need to have an inspection sticker and they do not check safety only emissions by plugging into the OBD port. No codes you pass.
one92rs
South Central Region
Nov 14, 2010 03:29 PM
primer84z
South West Region
Aug 8, 2002 12:48 AM
Mysticaldrumer
Jul 21, 2002 01:43 PM
