Cleaning off speedometer glass
Old Feb 7, 2023 | 11:04 AM
KITT87's Avatar
Car: ‘87 Base Firebird
Engine: 2.8 V6
Think I’m putting this thread in the right place,
Yesterday when I was out buying parts, one of my buddies decided to clean my speedometer glass off with goo-gone. It fogged it up pretty badly, what’s the best way to remove it? Thanks for your time.
Old Feb 7, 2023 | 11:06 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cleaning off speedometer glass
Might have to use plastic polish or cd scratch cleaner.
Old Feb 7, 2023 | 11:14 AM
KITT87's Avatar
Engine: 2.8 V6
Sounds about right, thanks! Do you have a brand recommendation?
Old Feb 7, 2023 | 11:17 AM
Engine: Lb9
Transmission: M20
Amazon Amazon
might test in a area that isn’t shown . It’s hard to tell in pictures how bad it messed up the plastic. If that doesn’t work
@firebirddude142 might have a used lens.
Old Feb 7, 2023 | 11:27 AM
KITT87's Avatar
Engine: 2.8 V6
https://www.amazon.com/Meguiars-Plas...91303000&psc=1
Gotcha, I attached some more photos here if that helps.
Old Feb 7, 2023 | 01:10 PM
tajefe's Avatar
I had this happen on a newer vehicle using an interior detail cleaner. Polished on it with rubbing alcohol to remove the residue. Maybe worth a shot in a test area 1st.
Old Feb 7, 2023 | 07:26 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I used the Plastix to polish mine, and remove normal wear. And that took ten passes or more to achieve a satisfactory result. It is a VERY VERY MILD abrasive.
The Goo Gone has essentially melted the top layer of the plastic. My "guess" is that you will have to remove that layer with something pretty aggressive, and polish back from there. I'm thinking some very fine steps of wet sanding, just like bringing back dull paint. Or at least an aggressive compound of some sort. A polisher (machine) wouldn't hurt either. It'll be as nice as new when you're done.
Old Feb 7, 2023 | 07:37 PM
KITT87's Avatar
Engine: 2.8 V6
I ended up polishing it with PlastX for a good while and got it all off, looks better than ever before. As DynoDave mentioned, it would’ve been better to start off with some very fine wet sanding but it did end up clean regardless. Thank you guys for helping me out!
Old Feb 7, 2023 | 07:40 PM
DynoDave43's Avatar
Glad you got it done!
Old Feb 15, 2023 | 06:01 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
Did you throat punch your friend?
Old Feb 15, 2023 | 06:24 PM
KITT87's Avatar
Engine: 2.8 V6
That was step one of the repair
Scotty54
Nov 15, 2022 07:23 AM
lordmetalz28
Jul 17, 2010 08:54 AM
omnipotentgoku
Jun 25, 2009 03:07 PM
HeavyMetal350
Mar 26, 2009 08:43 PM
joshp14
Jan 17, 2003 09:29 AM
