engine paint question
Old Feb 10, 2002 | 05:25 PM
EROCK's Avatar
I have the block pulled to have it re-worked. While it is out, I was going to paint it the same color as my car. What paint do I need for that? It is code 34 dark bright teal (1991) Thanks
Eric
Old Feb 11, 2002 | 12:13 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
go to your autoparts store and look for hgh temp paint in whatever colors they have
Old Feb 11, 2002 | 10:27 PM
Blue502's Avatar
Regular automotive enamel mixed in the color of your body should work just fine. Only place you would have any problem would be on the heads near the exhaust ports, or on a painted intake manifold.
Old Feb 12, 2002 | 08:20 PM
EROCK's Avatar
Well, I already have high temp paint (1500 degrees) for the heads and headers. The intake I am going to leave plain aluminum. All I was looking for is enough to do the motor block itself. I am sure that the heat will bake it on real good. Will I have to clear coat it like I do the body?
Eric
Old Feb 13, 2002 | 11:58 AM
Black85TransAm's Avatar
I don't think you'll have to claer it but i am with brodyscamaro on this.......
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
