Restoring TPI Plenum
Old Mar 5, 2002 | 11:19 AM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
Are there any methods or products that will restore the TPI plenum back to looking new again? I have been searching and all I can find is polishing or powder-coating them. I want it to remain stock lQQking without having to polish them. Any help will be appricated.
da BEAST
Old Mar 5, 2002 | 11:59 AM
Drew's Avatar
stainless steel wire brush, and eagle 1 rough cast aluminum wheel cleaner. Pull the plenum off the car, spray it with the wheel cleaner, rinse after 30 seconds or so... if any marks remain use the brush to shine it up.
Old Mar 5, 2002 | 07:36 PM
da BEAST's Avatar
Thanks for you response. I was also told that I could sand blast it with a mild sand. Any response to that?
Old Mar 5, 2002 | 07:57 PM
vortech305's Avatar
i had mines sandblasted at the machine shop for free since they rebuild my motor the most itll cost u is $20.00 if that. Looked brand new and clean.
Old Mar 5, 2002 | 10:15 PM
trigger GTA's Avatar
Car: 92 TA vert
a light sand blastind will work very well to return it to stock
Old Mar 5, 2002 | 10:34 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Sandblasting, or have it wheelebrated at a foundry. The wheelebrated gives a darker color to the metal. If you've everseen brodix parts then you'll know what I mean.
Old Mar 6, 2002 | 11:16 AM
Mooose's Avatar
plenum detailing
<http://www.gmtips.com/3rd-degree/dox/tips/tips.htm>
Go to this link and scroll down to the "Buffing Aluminum" section. Plenum polishing is listed there along with a bunch of other good info.
Happy motoring!
Old Mar 6, 2002 | 02:12 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
Have it glass beaded dont have it sand blasted sand blasting will make it look gray.
Old Mar 6, 2002 | 09:48 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
First removing the plenum from the car will give you many more options. If you blast it I agree with above post use glass beads not sand and be aware you will have to thoroughly clean the ports (EGR) to remove every spec of residue.
Myself, if you want to retain the stock look, I would remove it and clean it as stated above. Ordinarily I hate Castrol Super Clean as it will ruin an aluminum clearcoat or buffed aluminum but it would probably be perfect for what you are doing.
Then see how it looks before blasting. Blasting will magnify any imperfections. If you have a nick, it will get bigger, a pit, it will get bigger. It's called "dragging" an imperfection and it is inherent to cast aluminum.
If your plenum is not how you want it after you clean it I would get a good high quality paint from Eastwood Company and kind of fog it on from a distance to add some color and consistency. The plenum doesn't get that hot.
MantyZ28
16
Dec 21, 2015 11:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
