Black junk on tb and plenum
Subscribe
Mar 18, 2002 | 08:39 AM
What exactly is this black junk inside my plenum and TB. I took my plenum off to grind the walls behind the TB, and their was this black junk in it. It was also on the butterflys of the TB.
What is the best way to get this junk off. Carb cleaner should do it . Will it be safe with the tps on the TB.
Im not trying to be dumb. I didnt know if this is like carbon buildup on valves.
I am replacing my afpr, so I want to get the plenum and TB clean before I put it back on.
Is there anyway to keep this from happening again?
Reply 0
Mar 18, 2002 | 11:26 AM
That black stuff should be carbon deposits.I think you need some stuff thats safe for fuel injectoin instead of using carb cleaner. I think I've heard about some lining on the inside of the plenum that gets sripped off when you use certian chemicals. So I'd go the safe route and find some FI safe cleaner.
Reply 0
Mar 18, 2002 | 11:34 AM
Quote:
Yup thats what it is. Its gonna come right back though.
Reply 0
Mar 18, 2002 | 11:48 AM
You can clean it off with carb cleaner, TPI and MPFI parts aren't coated. But there's no point since the EGR pumps that crap thru the plenum by design.
Reply 0
Mar 18, 2002 | 03:28 PM
I figured It would come back. I realy want to clean the TB though.
What is the best way to clean the outside of the TB and Plenum. I dont want to polish it, but it is dirty. Would aluminum wheel cleaner work for the plenum?
Reply 0
Mar 18, 2002 | 04:41 PM
Carbuerator cleaner.
Reply 0
Mar 19, 2002 | 09:36 AM
Quote:
Yes.
Reply 0
Subscribe
