Sorry to ask this, but about polishing rims???
Old Mar 29, 2002 | 10:42 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
OK, I talked to my Dad about it and he said it wouldn't be necessary to take the aircraft stripper to my wheels to remove the clear coat on the non-painted parts (that's all I'm doing for now), he said that the sand paper should take it all off, does this sound right, makes sense to me..
I'd like to avoid the clearcoat stripper, since my tires will be on the wheels.
Old Mar 29, 2002 | 11:45 PM
bandit45's Avatar
Well I'm not a pro on the subject, but I'm polishing mine right now I still have the tire on it too. But in my experience it will be alot easier with the remover. I bought mine from auto zone and used a paint brush to apply it, its not that hard at all.
good luck
Old Mar 30, 2002 | 12:31 AM
Jza's Avatar
Jza
It's not necessary, but it's a few thousandths of an inch less material you'll have to sand down. Just apply and wipe off.
Old Mar 30, 2002 | 07:20 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Use the aircraft remover, thats what im using, I got the spray at auto zone for 5 bucks. I just left my tires on, as long as you try not to get it on the tires, you'll be alright. If you do, just wipe it off quick. Good luck, cant wait to see 'em when your done!
Old Mar 30, 2002 | 07:32 AM
trigger GTA's Avatar
Car: 92 TA vert
your old man is right. you dont NEED to use stripper you can just sand the clear off. i did not use stipper. if you have a power sander it will go even faster
Old Mar 30, 2002 | 07:39 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
it's a lot more sanding that way, but eventually you can sand right through all the clearcloat. I would definitely not attempt it by hand though.
Old Mar 30, 2002 | 05:49 PM
MikeDwhoROCZImports's Avatar
I did mine with aircraft stripper and the tires on. Like said above, just wipe it off when it hits the tire.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
