OER Weatherstrip
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
OER Weatherstrip
Just installed OER door weatherstripping today.
Could not afford Gm at $135 each, so I went with OER at $70 for both doors.
Not real impressed with the fit or quality.
The real problem is the molded ends.
The drivers side is like it is formed too big.
The passengerside is too small plus the mounting holes on the ends do not hardly line up.
Had to actually drill another hole on the passenger door.
Wish I could have afforded GM pieces.
My friend got a set of OER t-top weatherstrip kit last fall.
Had one side split into while installing!
Guess you get what you pay for.
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
YEP just installed new t-top seal kit and they are not doing good at all. Small tears and yes fitment troubles. Should have went GM too.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My Soffseal t-top gaskets fit flawlessly. My soffseal door gaskets fit flawlessly except for a little extra material at the front of the door where you can't see it. My soffseal hatch weatherstrip fits flawlessly.
Overall I'm very happy with the t-top and hatch weatherstrip. I'm 95% happy with the door weatherstrip, but I think I would have been happier with the OEM door weatherstrip.
Perhaps I'll try the Metra door weatherstrips in the future.
A follow up:
The OER weather strips are being sent back for a refund.
I got a surprise while washing.
They wear completely split into.
Still can't swing the GM ones.
I guess I will try Softseal brand at $90pr.
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
I got a full set of Softseal off e-bay, quite impressed atm, ok they are not GM [those cost more than my car].
The only thing i need to do is drop the side window adjustment a bit , the seals are so good i have to slam the door hard!!
I bought the OER. Same results. Salesman at Classic Industries said that they were made by the same manufacturer as the GM. HA!!!! Not only did they not fit, but when I tried to remove them to MAKE them fit they tore apart. TOTAL CRAP!!!! Bite the bullet and get the GM. Pull out the credit card and go deeper into debt like the rest of us.
Engine: Cammed 6.0L LSX
well i'm glad i read this post b/c i am getting new weather stripping put on the convertible top in a few weeks when i get a new top put on....i'm definatly going to go with GM...
Did a search here last night on Soff Seal.
Seems a couple of people are describing the same fitment issues that I have had with the OER stuff.
I've decided to bite the bullet and go with GM.
All I needed to read was just one complaint to change my mind.
Guess I'll have to put off some other parts I was going to buy for a while.
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have used softseal on my doors about 2 years ago. They worked but left a lot to be desired. The ends were too big and felt like cheap sponges. Also the GM parts have a "backbone" plastic inbeded in the ends and the strips have very large barb "T"s that go into the strips. Softseal has no "bone" and almost no "T". The barbs practically fall out of the strips if u r not carefull.
To thier defense i have herd that they have changed. But I still don't trust them one bit.
I think the cheapest or at least BEST set up would be:
-hood cowl (if you still have a stockish hood)-Softseal
-Hatch - Softseal
-Triangle from window-Ebay used
-Doors (don't look at the price, just order)- GM
-Windows (also look away)- GM
expensive but will def work and last. Leave all the idiot proof pieces to softseal, but when it comes to the precise important stuff leave it up to the general, haha.
-Hatch - Softseal
to my knowledge all the stripping on my car is still good except for the door and convertible strips.
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
I also went with Metro. I have seen the Soffseal tho and was able to compare the two.
The Metro ends were not formed as nice as I had hoped, but they were solid rubber. The flaps that get screwed to the car did not have the backbone which was the thing I missed the most. But, the length of the rubber seal was durable and shiney although it was hollow. Thats why I went with Metro. Install was OK vice screwing the ends down I used some small washers to be safe. At first doors a little hard to close but after a couple weeks its better and the doors sound more solid now.
The Soffseal was opposite in construction. The molded ends were hollow and the length of seal was solid, but it looked cheap and felt kindof flimsy. Looked like it could tear easily, more sponge feel than rubber. Only good thing it did have a backbone built in, but not as complete as GM.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i'll never put aftermarket weatherstripping on again, i have to constantly slam my damn doors, and it's been on there for 5 months
Engine: LS3
I am going to painfully cough up the $ for GM stuff......
slowly but surly get all the parts.
slowly but surly get all the parts. TGO Supporter
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Car: 89 camaro rs
Engine: 2.8l V6
Transmission: auto
Axle/Gears: 10 bolt 3.42
I use this product "armor-all" to make mine last as long as humanly possible. its quite impressive stuff. Really makes the rubber look and feel like new. the GM weatherstripping cost more than my car, too !! come on, now , why does it have to be THAT expensive ??? GRRR
Car: 1987 Z/28
Engine: 1988 5.0 TPI
Transmission: 700R-4
Axle/Gears: 10 Bolt, 2.73
Weather Strip Blues
My weatherstripping is TOTALLY gone in my car. T-tops, doors, back glass, hood, all need replaced.
Looks like I will go with a mix of GM and softseal. More bucks to shell out!
Looks like I will go with a mix of GM and softseal. More bucks to shell out!Supreme Member
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
ok, just how much is the GM weatherstriping for the doors and where the window goes up to on a non t-top car??? Shoukld I start crying now?
Car: 89 camaro rs
Engine: 2.8l V6
Transmission: auto
damn , I just deleted the reply I got from gmpartsdirect because I was so disgusted
It said something like $135 for the lower, inner door strip. And remember, these guys are supposed to be the cheapest GM parts resource !
I believe a T-top set was something like $449 or something of that order.... argh !
It said something like $135 for the lower, inner door strip. And remember, these guys are supposed to be the cheapest GM parts resource !I believe a T-top set was something like $449 or something of that order.... argh !
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
Re: OER Weatherstrip
Hi there, can you post some pics of your rear hatch soft seal rubbers? and doors to.thanks.
Car: 85 Trans Am
Axle/Gears: 342
I too got screwed with the OEM t top weatherstripping from Classic Industries. I bought the 8 piece set for 300.00 Fits like crap at the A and B pillars. Complete trash!! I'll be calling them tomorrow for a refund on this junk!
We are sorry to hear that you are having installation difficulties, but are happy to do what we can to try to help you. Please private message me here and we will take good care of you. Please note that there was a 1st design and 2nd design weatherstrip style with the second design having a more square edge than the first. I believe GM changed this design to improve the sealing some time around 1985 or 1986. It will look a little different than the 1st design seal, but is designed to function properly. We do offer the GM seals if you are not happy with the reproductions. PM me and I will give you my direct email to get you taken care of. If you could send me some pics of the problem areas, it might help. Thanks.
Ray Yager
Merchandising Director
Classic Industries
Car: 1986 Trans Am
I am going with the Metro weatherstrips when I do mine.
You can get their kits pretty reasonable on amazon
Hardtop part # 1900-105 $135
T top kit part #2001-118 $249
These include the doors the hatch and t tops
They were at the Syracuse nationals, I stopped in and they had some display pieces, I was impressed with the quality of the rubber, looked nice and very soft and pliable
Car: 85 Trans Am
Axle/Gears: 342
I meant OER not OEM lol. I sent some pictures to Classic Industries of how these T Top seals fit. They said they would refund my money if I sent them back. I'll be happy with that. Turns out my local Dealer can't get the GM seals anymore. If Classic refunds my money for the OER seals I'll buy the GM ones from them. If not, I guess I'll find another supplier
So far though Classic Industries has been very helpful with this issue.
So far though Classic Industries has been very helpful with this issue. Joined: Jun 2000
oer is junk, get soffseal. Cheap from summit!!!
Car: 85 Trans Am
Axle/Gears: 342
Hmm y'all got me thinking now... I see Summit has Metro and Soffseal. Are the Soffseal's made like the original GM ones?
I don't know if they are exactly the same but they are nice and soft. I couldn't get the doors to shut with OER crap on a couple of 2nd gens and 3rd gens and the soffseals fixed it. They close easily like stock.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Thread revival:
My OER door seals fit great & they are almost 10 yrs old! I will say, when first installed it was pretty hard to fully shut the door.As the ends were very rigid/bulky, but after a few months they "formed" very well to the door jamb.
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
Engine: 4++,350 & 305 CIs
Hello TAmaniac,
Ray Yager
Classic Industries
Ray Yager
Classic Industries
The 1st to 2nd design change came along in mid to late 1989.
I have NOS sets of both designs.
Yes... You are correct. They used the second design for one year around 1988. However, we show that GM then superseded back to the original design the following year.
I have original 89 cars here with the early cars having the 1st design and later ones with the 2nd design.
All ten original ttop seal, 90 thru 92 cars I have here also use the 2nd design with the extra water channel.
The instruction sheets I have from GM show the difference in the designs as the hard plastic outer ttop part and the extra lower water channels built into the Ttop seal that's on the car body.
There was also something in the press release about the 2nd design that said it was silicon impregnated to help them stay softer and seal better.
If I can find time I'll scan them.
Ray Yager - Merchandising Director
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
