4th gen rear end e-brake cable
Old Apr 17, 2002 | 10:23 PM
jawzforlife1's Avatar
need help real fast.
E-brake for 4th gen rear end.
Did the rear end swap:
so everthing is in except for the the e-brake cable. I bought 4th gen cables but when i went to put them in i noticed something. I dont have the ajustable "box" under the car for the cables. It goes from the handle to under the car. then it spits into the 2 cables to each wheel. Is anyboby else missing this adjustable peice. If i had it the 4th gen cables would fit. Now they are about 2 inches to short.
Use this link to reply:
https://www.thirdgen.org/techbb2/sho...hreadid=100964
Old Apr 21, 2002 | 06:24 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
You must use different cables. The 4th gen cables won't work.
I might have a set. But I will have to look around.
Thanx,ANDYZ28
Old Apr 21, 2002 | 04:00 PM
Sorry, swap is allready finished. I used 4th gen cables and some cable claps to make it work.
Old Apr 25, 2002 | 03:36 PM
FiReBReTHa's Avatar
thanx jaws for the visual therefore whenever someone searches for:
KEYWORDS: Fourthgen Fourth gen Rear end rearend Swap
they will find this
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
