how do u take off gfx on 91 fbird door?
Car: 91 Firebird GTA
i have a body kit in ready to be installed except when i was looking at the gfx on the door-i couldn't find any way of removing them-anyone know how do do this???
one more thing-the side gfx (under the door) to take those off they get unscrewed by the wheel wells and under the door right?
thanks
thanks
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
To remove the "under the door" gfx, you just need to remove all the screws on the bottom of the car holding it on along with the ones in the wheel wells, then take them off the bracket that is holding them. The bracket is on the rear of the front fender and appeared to be riveted to the fender if I remember correctly. I tried everything to get the gfx out from that bracket but the gfx eventually tore in that little spot. While I haven't taken the door ones off yet, I believe you have to remove the door panels and get them from inside the door.
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
You need to put the window up, remove the door panel, and youll see all the bolts. The under door ones are no problem. Unscrew the screws in the door jamb, un bolt the bolts in the fenderwells, and under the car, and itll slide right off.
