Air Flow Blockage?
Old May 1, 2002 | 12:14 PM
fourspeed's Avatar
Air Flow Blockage?
IF YOU LOOK DOWN THRU THE HOLES WHERE THE AIR FILTERS SIT ON AN IROC YOU WILL SEE A BLACK PLASTIC SHEET/COWL (ABOUT 6 INCHES DOWN FROM THE TOP OF THE RADIATOR)....WILL THERE BE A COOLING PROBLEM IF THIS IS REMOVED? I WOULD THINK MORE AIR WOULD BE FLOWING INTO THE AIR FILTERS IF THIS WERE REMOVED
THANKS
Old May 1, 2002 | 12:39 PM
89Irocz23's Avatar
no problem at all
I cut all my air boxes out and made it so when u take the filters off you can see the ground. I have had no over heating problem or anything and I noticed I pull more at higher RPMS. I run at about 185-190 and I live in Florida. So I would cut the air boxes out. There is a tech article check it out.
Old May 1, 2002 | 03:01 PM
camaro6spd's Avatar
or save your stock box, and go get one to cut out from a junkyard....i was lucky...i could save my stock box and use the one from the 87.....i am saving all the OEM stuff for a restoration later on in life....if i keep the damned thing.....****n wind noise in convertible....
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
toronto formula
Sep 10, 2015 07:31 AM
scotrans am
Sep 5, 2015 04:26 AM
