Power door lock (2 problems).....
Old Jun 13, 2002 | 07:33 PM
jeff's Avatar
Hey guys, I have a viper alarm system with the keyless entry, but when I go to unlock the car, the drivers side one will partly unlock, but not all the way, and the door will not open. The lock thing on the inside will slide out, but not all the way, it acts like its stuck. How do I fix this? Also, today when I went to press the unlock button(on the inside of the car on the door panel), the buttons fell into the door. Now there is a hole in the door where the lock unlock buttons are supposed to be. Why did this happen and how can I fix it?
Old Jun 13, 2002 | 11:34 PM
2vmodular's Avatar
here's a thread pertaining to the sticky lock issue
https://www.thirdgen.org/techbb2/sho...hreadid=112183
use the search feature and you'll find lots more info on the topic.
As for the lock button falling into the door, it sounds like the panel retaining tabs are cracked. New lock panels are less than $20 at the dealer. Might be a good idea to pick up a new lock switch too, they are less than $10/each at the dealer.
Old Jun 14, 2002 | 08:12 AM
polishdevil's Avatar
Car: 88 GTA
You can also just hot glue the lock/unlock switch from the inside and save urself some money.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
