Door/Hinge alignment
Old Jun 20, 2002 | 12:29 PM
MD83Z's Avatar
My new junkyard door needs to be shimmed out a little and up some.
I belive the body post for mounting hinges has been turned in at the front slightly, from the over-opening of the original door.(crumpled the sheet metal)
Can this be solved with washers to shim, or should I try moving the unibody with an old hinge and come-along?
Thanks for the other response Andy.
Old Jun 20, 2002 | 01:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are you sure it's the door? Have you checked the alignment of the fender? If you loosen all the upper fender bolts, you'll find that you can slide the fender in/out from the frame. I'm betting that the fender is too far "in" towards the frame, which makes the door look like it's too far "out".
Keep in mind that by loosening/readjusting the fender, that the hood hinge bolts to 3 of the upper fender bolts. This means you might mess up the alignment of the hood to the fenders. No biggie. When the fender's "perfect", tighten down (not too tight!!!!! The upper fender bolts go into sheetmetal shims, not real nuts) all the upper fender bolts EXCEPT those that go for the hood hinge. Make those hood hinge bolts slightly tight (so the hinge doesn't flop around). Then play with opening/closing the hood until you get the alignment right. When the hood is correct, tighten the hoodhinge bolts all the way.
Also check the lower fender-to-body bolt. It's between the bottom of the door and the rear of the front wheel. Sometimes, people try to jack the car up using this bolt, and it folds under, and messes up the fender alignment. This might be why the door seems like it needs to come up a bit.
As you've probably found out, the mounting bolts for the door have a bit of adjustment in 'em.
Old Jun 20, 2002 | 01:48 PM
MD83Z's Avatar
I'm sure it's the door, it is in too far and scrapes at the bottom.
There is a little adjustmemt ,but not enough. My backing up incident with the door not closed fully messed up the door whithout hurting the fender.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
