vert ground effects
Old Jun 21, 2002 | 11:41 AM
89ragtop's Avatar
Car: 1989 Camaro Convertible
vert ground effects
What must one do to get the side pieces of the ground effects off? There is a bolt on the very rear of them that can be seen by removing a jamb vent and it is way down there, quite inaccessible by the looks of it. Must the stud be drilled out, or is there an easier way? I cant peel them aside far enough to look behind and see if there is a better way of doing it. Vert guys who have removed these, please share your thoughts. I don't want to damge mine unecessarily. Thanks.:lala:
Old Jun 21, 2002 | 12:08 PM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
I stripped one last week, and there is NO WAy to get it out.. I just kept hitting it with a hammer and chisel to get it out.... HOWEVER, if you Call MILANI AUTO BODY in Burnaby (Vancouver) BC they painted me car and figured out how to take it off... I think there is a hole behind the seatbelt that you have to pull out! Take a Look, and get a STRONG flashlight
Old Jun 22, 2002 | 10:37 PM
wuter's Avatar
well mines not a convertable but it should be the same, i took the rear plastic armrest things out and there is an opening for the nut to be removed.
Old Jun 22, 2002 | 11:19 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
We have a winner.
Old Jun 24, 2002 | 06:55 PM
89ragtop's Avatar
I'll try that then. Thanks.:lala:
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
okfoz
Oct 13, 2015 02:19 PM
lewandom
Oct 1, 2015 08:15 AM
