Need help... how do I get my back seats out?
Old Jun 25, 2002 | 06:35 PM
WS6Formula305's Avatar
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
I found one bolt in the center of the seat, underneath the front lip towards the floor... but that's only for the bottom portion. How do I get the fold down portion out (the seat back)? I'm assuming there's probably another bolt for the lower portion of the seat underneath the seat back after it comes out... but, instructions on how to take them out would be a big help. Thanks.
Old Jun 25, 2002 | 07:17 PM
Tonyrodz's Avatar
Transmission: auto
If it's a 1 piece rear seat there's a small bolt under the seat--right near where the retracting seat belt is(pre-89). If you stick your finger there you'll feel the bolt--just loosen it up, I think it's a 7mm but I'm not too sure. There's 1 bolt on each side so you'll have a total of 2 bolts. for the 2 piece rear seat it's the same thing except once you take out each bolt you have to slide the seat back out of the rod that's in the center(welded to the hump).
Hope I made it clear--it really is very easy to do.
Old Jun 25, 2002 | 07:39 PM
bollox's Avatar
I just took mine out out recently and it's real easy once you figure out where the two bolts are then you just got to slide it off the center bar, like Tony said.
Old Jun 25, 2002 | 09:10 PM
HamsterOnaMission's Avatar
and the bottoms are only velcro's at the back
Old Jun 25, 2002 | 09:32 PM
HrdRockA4305's Avatar
There are 2 either 11 or 13 mm bolts, I don't remember, holding the fold down seat back in. One on each side just below the hinge. You'll probably need a wrench, I had a hard time fitting a rachet in there. They are easier to feel than see. Just take the nut off each hinge and it comes right out. Took me about 2 minutes to do while swapping seats. I put a step by step on this in t he thread I posted a while back called "Check out what I did this morning" or something like that.
Old Jun 26, 2002 | 04:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I believe the nuts from the folding seat back are 10mm, and the center bolt in the middle of each seat bottom is a 13mm.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
lee01
Apr 9, 2016 01:56 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
