weather stripping
Old Aug 6, 2002 | 03:26 AM
89rskelly's Avatar
weather stripping
i just bought weather stripping for just the doors of my camaro ( 89 rs ) ... has anyone done this job or should i get it done somewhre ... some people have said its a pain in the *** and if u mess up its hard to fix it ... input please
thanks kelly
Old Aug 6, 2002 | 09:06 AM
Mathius's Avatar
Weatherstripping in general can be no fun, the weatherstripping adhesive is very messy and can get everywhere. I haven't done my doors, but I've done the whole t-top kit, and the hatch. Make sure you've got the right adhesive (3M makes one, I can get the part number if you need it), and get 3M's adhesive cleaner as well. Not only does it clean the surface you're working on, but if you spill any or make any messes, it will clean that up too.
My suggestion, get the weatherstripping, take your old one off, clean it up with the 3M stuff, and then just lay the old one on to get a feel for how it should fit. Then go back and do it a section at a time. It helps to have another person work on this with you. They can apply the adhesive, while you set down the weatherstripping, or vice versus.
I don't want to discourage you, it isn't terribly difficult, but it can test your patience because you only have a small window of time to work with before the adhesive makes a mess or begins to set. Also, space can be very restrictive in some places. For example, the t-tops weren't that big a deal, but doing the hatch seal was very difficult up on the top, where the hatch glass was in the way of my work.
Good luck.
Mathius
Old Aug 6, 2002 | 06:03 PM
89rskelly's Avatar
thank u :)
thanks a lot ... i think that ill give it a try ... whats the 3m stuff called and can i get it at pep boys or a performance shop ?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
3.8TransAM
Oct 1, 2015 07:47 PM
Nick McCardle
Sep 10, 2015 08:36 PM
