best way to remove dents
Old Sep 15, 2002 | 07:53 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
should i try the ding king since i need a paint job anyways? j/k
or should i just filled them in with bondo and prime away?
whats the best method that i am capable of, because i am not very good with body work
nothing too serious, just a few little dings here and there
Old Sep 23, 2002 | 04:47 AM
Sciguyjim's Avatar
I'd check out the easiest/cheapest methods first. There's a new thing with 3 suction cups being advertised on tv now. Looks easy.
Old Sep 23, 2002 | 07:00 AM
camaro6spd's Avatar
hammer and dolly........as little bondo as possible.
Old Sep 23, 2002 | 01:58 PM
CrazyHawaiian's Avatar
Car: too many ...
yeah dont bondo unless you have too. if you push it carefully from the back you might not need to repaint some areas (depending on dent). if you pull em from the front expect to repaint some parts ...
Old Sep 23, 2002 | 07:24 PM
hmmmm the only places the car really has any dents are on the doors...............they are small too
so whats the best idea......take of the door panel and try to push the dents out as best as possible, then bondo if need be?
Old Sep 23, 2002 | 08:22 PM
Car: too many ...
Yeah if you can get to the backside of the dent then you can roll it out and you'll have a better chance of saving the paint. I'm not sure if you'll be able to get at it tho, I havent been behind the door panels in a while. Window might need to come out too.
Old Sep 23, 2002 | 09:36 PM
car needs to be painted anyway..........
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Stroopwafel
Sep 11, 2015 06:38 AM
hydrolic144
Sep 8, 2015 06:59 PM
