black t top bar
black t top bar
When I take my t tops off there is a divider between the two sides. This appears to be held in by three screws on each side. This bar seems to have rust and I would like to take it out. The problem is that I cannot seem to find how to remove it. I take the screws out, but the bar does not want to go. Any help on how to get this bar out would be great. Is it one piece? Thanks
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by Saywhut
I think there's 5 screws on each side, the very front and back ones are probably under the weatherstripping. And it was installed by the factory with sealer, you'll have to pry it some. Be careful!
Originally posted by 383 rocket bird
Thanks I was gonna take it out and maybe buy a new one. Any idea if anyone is selling them new.
Car: 1986 Trans Am
Gmpartsdirect.com
Check these guys out.If you don't know the part number just give them your info.They have some of the best prices around.I bought alot stuff from them and I'm a happy camper.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You can low-ball the dealer to sell it to you GM wholesale price of just above $83 otherwise you'll pay retail of $110ish. GMPartsdirect will sell it for $65ish but shipping will bring it close up to GM wholesale.
http://www.deadbird.org/pncam/index.htm if you want to find out for yourself.
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
hey thanks for the info on the t top because i have the same problem with mine and i was trying to take mine off but it wouldnt budge
now i know that there are 5 screws. my t top leaks in 2 spots so i was thinking of taking of that black metal peice and where ever there is rust to cover it with silicon. what do you guys think. i gotta stop this leaking, my car is starting to smell moldy
also in the rear of my car the water leaks in under the weatherstripping and pours into the rear little lockable storage box. any ideas of how to fix that? thanks a lot
bub
also in the rear of my car the water leaks in under the weatherstripping and pours into the rear little lockable storage box. any ideas of how to fix that? thanks a lotbub
they that fools alot of people, because who would guess that their are screws under the weatherstripping..
but i found out when i parted out my camaro and i just tore up everything around it to get it off.. much more easy to find out whats holding it when u dont care if you mess up the stuff around it..
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ProtoMaster22
Aug 26, 2015 07:50 AM
NBrehm
Aug 5, 2015 07:57 PM
