Air Compressor Selection
Old Sep 21, 2002 | 10:41 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
I'm going to be purchasing and air compressor and I need to know what things I should look for. I'm looking at craftsmans, but I need to know what the baseline scfm @ 40 and 90 psi that I will need to use body work tools is. Thanks!
Old Sep 25, 2002 | 02:02 PM
Robz84Monte's Avatar
make sure the motor is 2 stage. I have a craftsman 2 stage 25 gal. works good but does need breaks to recharge from time to time. i use mine for body work too and have no complaints.
Old Sep 25, 2002 | 03:11 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Look up the body tools on the net, or at Home Depot, or etc. Then compare them to air compressors. Check out http://www.northerntool.com for some big ones! Mine is a 5 HP single stage (120 volt) 20 Gallon Campbell-Hausfeld, and does okay with normal tools. The D/a sander usually drains my compressor fast when I use the sander at full throttle, but I've found the d/a is pretty effective at half-throttle. And the paint gun I bought (Devilbiss Finishline II HVLP) doesn't use much air at all (low SCFM @ low psi)- I haven't used the gun yet but according to the specs, I should be fine.
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
scotrans am
Sep 5, 2015 04:26 AM
Billy Decker
Sep 4, 2015 03:46 PM
mrdevontay
Sep 2, 2015 08:04 PM
