what is a D/A sander?
Old Sep 23, 2002 | 09:38 PM
ohohblita's Avatar
and how do i wet sand?
need to sand my rubber spoiler...
thanks...
Old Sep 23, 2002 | 10:22 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I'm pretty sure it stands for Dual Action sander. Wetsanding is done by sanding and keeping what you are sanding wet at all times. It can remove fine scratches and be buffed to a great shine when done right. I'm not exactly sure on what grits to use, so I'll let someone else take it from here.
Old Sep 23, 2002 | 10:52 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Yep, you got it man, DA stands for Dual Action Sander.....they are great! They make them in 5 inch, 6 inch, and 8 inch. Well....if your wetsanding something.....it depends how thick the paint is. Like on the spoiler your talking about.....I would probably use anywhere from 400-600 grit.....that's just for taking the paint down. Now.....if your wet sanding to buff a shine.....I use 1500 grit for that.
Old Sep 24, 2002 | 07:30 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you're wetsanding to buff it, forget about the D/A and grab a sanding block and do it by hand.
If you're sanding to remove paint, don't waste your time with water. Just dry sand. Wetsanding with a d/a makes an unbelievable mess and isn't really going to offer much of an advantage. The purpose of wetsanding is to keep the paper from plugging up, but it's rare that you'll plug the paper when you're using a D/A.
bnoble
Aug 23, 2006 12:56 AM
Rabbitt
Jul 1, 2005 07:35 PM
IroczInOz
Apr 11, 2005 11:19 PM
benoit454
Apr 13, 2004 01:45 PM
Night Hawk
Car Audio
Apr 24, 2001 11:41 PM
