air-dam question
Old Oct 11, 2002 | 03:23 PM
Camarokid01's Avatar
air-dam question
I have an 86 sport coupe camaro that does not have ground effects, but I recently put on the front and rear bumpers and side skirts from an 85 IROC so now the car has the ground effects. My old air dam was attached to a long plastic piece that covered up the underside of the front bumper but that piece no longer fits with the new bumper and ground effects. So my question is do the cars with ground effects still have that big long plastic piece attached to the air dam or is there just an air dam there?
Sorry my explination isnt that great, but thanks in advance
Old Oct 11, 2002 | 05:33 PM
AT4 T/A at work's Avatar
I'm not sure exactly what you mean. I've got a Trans Am with ground effects, and the air dam bolts directly to the underside of the radiator support. I don't know if that helps or not...
Old Oct 11, 2002 | 06:45 PM
That does help unless camaros are different I just needed to know if the air dam was bolted directly to the car or if this long plastic piece was under the air dam also.
Thanks a lot
Old Oct 11, 2002 | 07:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you mean the mostly flat skinny black plastic piece ?
if so then thats the air damn itself. bolts ot bottom of rad support
Old Oct 12, 2002 | 02:28 AM
The piece that was also attached to the air dam when I had my sport coupe front bumper was a long skinny piece of plastic with 1 big square on each end, if any of you have a sport coupe/berlinetta you will see what I am talking about if anyone could post pictures that would be great.
Thanks again
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
