What is the cheapest way to re hang your cieling on a 1985 Camaro?
Old Oct 13, 2002 | 11:57 PM
SuPeR SpOrT's Avatar
Thats right, my ceiling is falling down in my camaro and I need to know the cheapest way to get it too stay up, I have a sunroof in it and it leaks so I need one that won't fall down when a little water bugs it...
Thanks guys
Old Oct 14, 2002 | 01:21 AM
9OFirebirdV6's Avatar
ghetto-fi it, use magnets!, or cut a slit in ait and spray it with 3M super adhesive then press it back up.
Old Oct 14, 2002 | 04:05 AM
guiltybyassoci's Avatar
I have used the headliner repair screws which are available at most auto part stores. They are black plastic buttons that you screw into the foam. They seem to work well as long as your headliner backing is not crumbling away. If that doesn't work pull it out carefully, if you don't pull it apart it can be fixed and recovered for less then half the cost of a new one. The 3m stuff will make a mess of your headliner and won't keep it up for long if your backing is crumbling away. It will stick to the loose particles and fall off plus it can seep through and make the material look really nasty. Another suggestion would be to go to the junk yard and pull one out of another car, recondition the backing, cover it then cut the sunroof hole and just rip out your old one, you can fix allot of leaks with the headliner out. There is alot of info on this board on fixing your own headliner.
Old Oct 14, 2002 | 05:07 AM
LarsZ28's Avatar
Sweet Sig man, thats been my computer background for a while.. I did a screen shot from the metallica "i disappear" clip.
Old Oct 14, 2002 | 09:22 PM
hmmm i laughed when I saw the magnet Idea but now that i think about it, it might work also the backing is crumbling away pretty bad on my camaro
I think I am going to have to go to the junk yard
Old Oct 15, 2002 | 12:22 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
you can buy headliner material at Jo-Ann fabric. Do a search for instructions. I've typed it out a bunch of times, as have many others. You'll get all you need by using the search.
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
Fronzizzle
Aug 9, 2015 01:15 PM
