Hood Question
Old Oct 17, 2002 | 02:31 PM
90RS3.1's Avatar
Hood Question
Im looking into purchaseing the ascd 'SS' stlye hood for my 90 camaro rs from Hawks. Has anyone used this hood and is it a good fit? What is involved with installing it? and can i use my factory lift supports? thanks
Old Oct 17, 2002 | 05:44 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hey Man, I just bought one of the SS ASCD from Hawks too....and it's on my 1991 Z28 5.7 (L98) and is bad ***!! I still have to paint it though. Well....I had it on in about 30 minutes with the help of about 3 friends. What I suggest is to get a set of used hood struts. I tryed to use my factory ones, but there is WAY to much pressure in them...and I didn't want to crack my hood. So.....you might go to a junkyard and see if you can get a worn out set. They work really well on fiberglass hoods.
Old Oct 17, 2002 | 06:44 PM
90RS3.1's Avatar
Thanks man i apprecite it. now im definitly getting it that i know it fits. Ill see how my hood struts work. ill try it without them first to see how it works. im guessin the factory hinges n stuff are fine. hmm i wonder if i have my old struts around
heres another question was it easy to aline or was it a pain....and is the hood already drilled n such.
Old Oct 17, 2002 | 10:18 PM
Engine: 5.7
Well.....the only thing I had to drill was the holes for the spring....for some reason....my weren't drilled. The hood also has pre-drilled holes with taps and bolts to where it bolts onto your hinges.
Old Oct 17, 2002 | 10:19 PM
Engine: 5.7
Well.....the only thing I had to drill was the holes for the spring....for some reason....my weren't drilled. The hood also has pre-drilled holes with taps and bolts to where it bolts onto your hinges. It really wasn't hard to align at all. Just leave some slack in the bolts....and lower it, then you can move it around and see where it needs to be bolted. You may need a couple of people to help though.....
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
